Home » Language IDEs » ServerTools (WTP) » How can I add JSP comments (instead of HTML comments) in Eclipse?
How can I add JSP comments (instead of HTML comments) in Eclipse? [message #991116] Mon, 17 December 2012 07:08 Go to next message
When editing JSP pages in Eclipse, I can comment out the current line or selected block with HTML comments using the keyboard shortcut CTRL+SHIFT+/:
However, in JSP files, I usually want to use a JSP comment instead:
Is there a way to add these comments with a keyboard shortcut instead/as well?
A minimum of 25 shiny Stack Overflow rep points are available. See Stack Overflow question #13912025
[Updated on: Mon, 17 December 2012 11:31] by Moderator
Re: How can I add JSP comments (instead of HTML comments) in Eclipse? [message #991404 is a reply to message #991116] Tue, 18 December 2012 17:28 Go to previous messageGo to next message
Hi Paul,
Unfortunately, there are no explicit keybindings for switching between the styles of comments used in a JSP file.
Instead, the keybinding for Ctrl+Shift+/ is overloaded in JSPs. If the selected region includes JSP-specific syntax (scriptlets, custom tags, etc.), Ctrl+Shift+/ inserts the JSP comment. So for example, <div><c:out value="test"></c:out></div> will be wrapped entirely in a JSP comment.
On the other hand, content that is not JSP-specific will use regular comments. For example, <div></div> will be wrapped in the typical HTML-style comment.
It changes once again to use Java-style comments, if only the Java content of a scriptlet is selected.
Re: How can I add JSP comments (instead of HTML comments) in Eclipse? [message #991880 is a reply to message #991404] Thu, 20 December 2012 07:05 Go to previous message
Cheers Nick, that makes sense. Many thanks for replying.
Previous Topic:Supressing / Removing problems from .js files programatically
Next Topic:Problems with Dynamic WebProject + J2EE Preview server on Juno
Current Time: Fri Jul 25 08:42:20 EDT 2025
Powered by FUDForum. Page generated in 0.04598 seconds
