Home » Newcomers » Newcomers » Debugger won't stop at breakpoints
Debugger won't stop at breakpoints [message #990993] Sun, 16 December 2012 09:01 Go to next message
Hi guys.
im new here and to C programming in general.
im trying to make the program run until a specified breakpoint, and then start debugging.
i set a breakpoint (by clicking on the left panel and marking the line with a blue dot), hit debug, and the debugger starts debugging from the first line, instead of running the program and stopping at the breakpoint.
how can i make it run the program and start debugging at a specific line?
im using:
Eclipse IDE for C/C++ Developers
Version: Juno Service Release 1
Build id: 20120920-0800
Thanks in advanced!
Re: Debugger won't stop at breakpoints [message #991159 is a reply to message #990993] Mon, 17 December 2012 10:14 Go to previous messageGo to next message
On 12/16/2012 02:00 PM, Stormey legend wrote:
> Hi guys.
> start debugging.
> im using:
> Thanks in advanced!
Do you have Stop on Startup at: Main checked in your Debug launch config
on the Debugger page? This will cause your program to stop at main.
You can hit resume and the program will continue till it hits a
breakpoint. You can also uncheck the Stop on Startup option in the
launch config. Then your program will run until a breakpoint is hit.
Re: Debugger won't stop at breakpoints [message #991221 is a reply to message #990993] Mon, 17 December 2012 15:33 Go to previous messageGo to next message
Hi David Wegener, and thanks for your help.
i couldn't find any box with "Stop on Startup at: Main" next to it.
i'm not allowed to use links to any other site but eclipse.org because i have fewer than 5 messages, so i can't post a picture of my Debugger Configuration window,
and i'm too affraid to change staff without knowing exactly what it does,
so i'll be really grateful if you could walk me through it...
there are six tabs there:
main
arguments
environment
debugger
source
common
none of them has "Stop on Startup at: Main" option.
although there's unchecked "Non-stop mode (Note: requires non-stop GDB)" option under the "Deubgger" tab.
what should i do next?
[Updated on: Mon, 17 December 2012 15:33] by Moderator
Re: Debugger won't stop at breakpoints [message #991620 is a reply to message #991221] Wed, 19 December 2012 16:40 Go to previous messageGo to next message
UP!
Please! this is really important to me.
doesn't anyone know how to fix this problem?
TIA!
Re: Debugger won't stop at breakpoints [message #991647 is a reply to message #991620] Wed, 19 December 2012 17:55 Go to previous messageGo to next message
On 12/19/2012 2:40 PM, Stormey legend wrote:
> UP!
> TIA!
Of course, you're asking in the newcomers' forum. As you're doing C/C++,
your touble might be flavored that way. So, you could re-ask in the
Eclipse CDT forum just in case there's more of a C/CC++ thing going on.
Just flailing around trying to salve your desperation.
Best of luck!
Re: Debugger won't stop at breakpoints [message #991736 is a reply to message #991647] Wed, 19 December 2012 23:37 Go to previous messageGo to next message
Will do. Thanks!
Re: Debugger won't stop at breakpoints [message #991946 is a reply to message #991736] Thu, 20 December 2012 09:22 Go to previous messageGo to next message
The original answer was correct. Just added an entry with screenshots to the FAQ to make it easier to understand:
http://wiki.eclipse.org/CDT/User/FAQ#How_do_I_prevent_the_debugger_from_stopping_on_the_first_line.3F
Marc
Re: Debugger won't stop at breakpoints [message #992033 is a reply to message #991946] Thu, 20 December 2012 13:16 Go to previous message
brilliant!
thank you so much!
it's crazy how i missed it...
[Updated on: Thu, 20 December 2012 13:17] by Moderator
Previous Topic:p2 installation question
Next Topic:How to extend "Switch Workspace" in custom CNF-navigator
Current Time: Tue Jul 29 00:52:42 EDT 2025
Powered by FUDForum. Page generated in 0.33048 seconds
