Home » Archived » M2M (model-to-model transformation) » [ATL] (3.0) New JAVA ATL3.0 launch procedure?!
[ATL] (3.0) New JAVA ATL3.0 launch procedure?! [message #99050] |
Fri, 06 February 2009 04:53  |
Does anybody know how to launch an ATL transformation with the new ATL3.0
libraries. I had a JAVA code that worked well, and i want to update it to
this new ATL3.0 version.
What seems not to work anymore is all the ATLEMFModelHandler operations
(save, load, getMof..).
Anybody knows about these modifications?!
Re: [ATL] (3.0) New JAVA ATL3.0 launch procedure?! [message #99112 is a reply to message #99098] |
Fri, 06 February 2009 10:09   |
Answers below:
Tristan FAURE a écrit :
> oops sorry it seems it exists is this extension :
> org.eclipse.m2m.atl.service.core.transformation is able to do what i
> meant ?
No, this plugin is an old one, it is no more maintained.
>> Hi !
>> I've downloaded with CVS last source of ATL and it's very good to
>> provide example for code transformation
Note that to ensure that you use the good plugins you can use the psf
files to download plugins.
http://wiki.eclipse.org/ATL/User_Guide#Install_ATL_from_CVS
The ATL3.0 builds also contains the examples, directly deployable using
the example wizard.
ATL 3.0.0M5 has been uploaded today, so feel free to test it!
http://www.eclipse.org/modeling/download.php?file=/modeling/ m2m/atl/downloads/drops/3.0.0/S200902051237/m2m-atl-SDK-3.0. 0M5.zip
>> but is it planned to provide a service for creating an equivalent of
>> org.eclipse.m2m.atl.examples.public2private.ui plugin depending of
>> user ATL file ?
The first intent of the public2private example was to provide a concrete
and working example of a programmatical use of ATL.
Now, it's clear that this kind of example (not only refactoring) is a
common case for many users, so we certainly will have to provide this
extension.
But I can't say exactly when for the moment :-)
William
>> or creating extension point referencing asm file and file extension
>> able to launch atl transformations ?
>> William Piers a écrit :
>>> Hello,
>>> Answers below:
>>> Skander a écrit :
>>>> Hi, Does anybody know how to launch an ATL transformation with the
>>>> new ATL3.0 libraries. I had a JAVA code that worked well, and i want
>>>> to update it to this new ATL3.0 version.
>>>> operations (save, load, getMof..).
>>> In the RegularVM (old virtual machine) context, those operations are
>>> now located in the ASMModelLoader class (and subclasses).
>>> There is now an example of java launching that you can directly
>>> install using the wizard:
>>> new->example->atl->public2private
>>> This example adds a popup when right-clicking on UML2 models and
>>> launches the refining public2private transformation (privatize public
>>> fields and generate getters/setters).
>>> Note that the new launching interface allow to launch both EMFVM and
>>> RegularVM, using same code. But you still can directly use the
>>> RegularVM api if you simply want to update your java code.
>>> Do not hesitate to ask if you encounter problems !
>>> Best regards,
>>> William
Re: [ATL] (3.0) New JAVA ATL3.0 launch procedure?! [message #99359 is a reply to message #99274] |
Wed, 11 February 2009 03:51   |
Skander a écrit :
> hi, do you have an example where you launch a transformation with an
> output model that has its own metamodel and with external helper libraries.
Sorry, not for the moment.
> I tried to adapt the public2private but i still have some problems,
> especially with the last parameter of the launch method:
> launcher.launch(ILauncher.RUN_MODE, new NullProgressMonitor() , options,
> new Object[] {asmURL.openStream()});
> I do not use the same initilization as the example publi2private :
> static {
> // ATL public2private transformation
> Bundle bundle =
> Platform.getBundle("org.eclipse.m2m.atl.examples.public2private ");
> asmURL = bundle.getEntry("transformation/Public2Private.asm"); ..
> because my transformation file (.asm) is described by (c:/..../trans.asm)
The first parameter is an InputStream, so you can try this way:
InputStream is = new FileInputStream(new File(c:/..../trans.asm));
//using java 1.4
options, new Object[]{is};
//using java 1.5
options, is);
And to include libraries:
launcher.addLibraries("LibraryName", libraryInputStream);
William
Re: [ATL] (3.0) New JAVA ATL3.0 launch procedure?! [message #99389 is a reply to message #99359] |
Wed, 11 February 2009 06:03   |
hello,
my question in this post is : "do i have to write the input file path in a
special way?"
i have tried this code:
try
ILauncher launcher = null;
launcher = CoreService.getLauncher("EMF-specific VM"); //$NON-NLS-1$
launcher.initialize(Collections.<String, Object> emptyMap());
inMetamodel = factory.newReferenceModel();
injector.inject(inMetamodel, "http://www.eclipse.org/uml2/2.1.0/UML");
IModel inModel = factory.newModel(inMetamodel);
File file = new File ("D:\\A....\\MARTE_XUPV2P.uml");
injector.inject(inModel, file.getPath());
launcher.addInOutModel(inModel, "IN", "UML2");
outputMetamodel = factory.newReferenceModel();
injector.inject(outputMetamodel, "http:///AADL/core");
IModel outModel = factory.newModel(outputMetamodel);
launcher.addOutModel(outModel, "OUT" , "AAXL");
InputStream is = new FileInputStream(new File("/Trans.asm"));
is);
extractor.extract(outModel, "/res/result.aaxl");
catch (Exception e)
e.printStackTrace();
///// But the injector.inject returns a file not found exception when i
give a relatif input file name, and returns a unknown protocol exception
when i give the absolute path of the file. do i have to write the file
path in a special way?
Re: [ATL] (3.0) New JAVA ATL3.0 launch procedure?! [message #99433 is a reply to message #99389] |
Wed, 11 February 2009 09:21   |
I finally could launch a simple transformation without libraries with this
code:
try
URL url = new URL("file://d:\\AA......ple\\MARTE_XUPV2P.uml");
injector.inject(inModel, url);
FileInputStream("d:\\AA...\\OneLevelMarteToAAXL_V2.asm");
is);
// Saving model
URL outUrl=new URL("file://d:\\AAD....le\\result.aaxl");
extractor.extract(outModel, outUrl);
catch (Exception e)
e.printStackTrace(); }
I'll try the one with the libraries now...
Re: [ATL] (3.0) New JAVA ATL3.0 launch procedure?! [message #99447 is a reply to message #99389] |
Wed, 11 February 2009 09:38   |
To clarify the various paths notation, I wrote a small wiki section
here:
http://wiki.eclipse.org/ATL/Developer_Guide#EMFInjector_.2F_ EMFExtractor_usage
William
Skander a écrit :
> hello,
> a special way?"
> try
> options, is);
> catch (Exception e)
> Thanks
Re: [ATL] (3.0) New JAVA ATL3.0 launch procedure?! [message #99941 is a reply to message #99622] |
Fri, 13 February 2009 10:03   |
hi,
i try to add an outPut model with this method:
private void addOutputModel(ILauncher launcher, String metaModelURI,
String metaModelName, String outputPath, String
modelName)
throws Exception
IReferenceModel outputMetamodel;
Map <String,Object> factoryOptions = new HashMap<String, Object>();
factoryOptions.put("modelHandlerName", "EMF");
factoryOptions.put("modelName", metaModelName);
factoryOptions.put("path", metaModelURI);
outputMetamodel = factory.newReferenceModel(factoryOptions);
injector.inject(outputMetamodel, metaModelURI);
factoryOptions.put("newModel", "true");
factoryOptions.put("modelName", modelName);
factoryOptions.put("path", outputPath);
outModel = factory.newModel(outputMetamodel, factoryOptions);
((RegularVMLauncher)launcher).addOutModel(outModel, modelName,
metaModelName);
I could add the model without any problems but i get this error message :
No type named 'AadlSpec' in metamodel '<unnamed>'
Like if the metamodel name was not correctly loaded (AADL in this case).
I have almost the same method (addInputModel) for input models but
everything works well for those.
Do you have any idea?
Re: [ATL] (3.0) New JAVA ATL3.0 launch procedure?! [message #99956 is a reply to message #99941] |
Fri, 13 February 2009 11:22   |
The LauncherService class defines utilities method to launch a
transformation with "classic" parameters (model names, model paths, etc.).
Note that if you are working with the CVS HEAD version
(http://wiki.eclipse.org/ATL/User_Guide#Install_ATL_from_CVS), there is
a simplified launch method which directly takes the defaults factories
and injectors. This was not available in 3.0M5 build but I think it
could be useful in your case.
You can see the AtlLaunchConfigurationDelegate, or ATLNonRegression
tests to see how it works.
William
Skander a écrit :
> hi,
> modelName)
> throws Exception {
> metaModelName);
Re: [ATL] (3.0) New JAVA ATL3.0 launch procedure?! [message #100060 is a reply to message #99956] |
Mon, 16 February 2009 09:52   |
The latest build integrates the new launch method:
http://www.eclipse.org/modeling/download.php?file=/modeling/ m2m/atl/downloads/drops/3.0.0/I200902160913/m2m-atl-SDK-I200 902160913.zip
William
> Best regards,
> William
> Skander a écrit :
>> hi,
>> modelName)
>> throws Exception {
>> metaModelName);
Re: [ATL] (3.0) New JAVA ATL3.0 launch procedure?! [message #100115 is a reply to message #99956] |
Tue, 17 February 2009 09:10  |
thanks william, everything is working well now. I took the
AtlLaunchConfigurationDelegate class from the
org.eclipse.m2m.atl.core.ui.launch package, then i changed the
"configuration" parameter of the launch method with my dataModel and i
modified the initialisations phase.
Everything works fine, just a little problem, all files (.asm, .uml, e...)
must be in my plugin project not somewhere else in the workspace.
thanks a lot
Current Time: Sun Jul 27 03:18:38 EDT 2025
Powered by FUDForum. Page generated in 0.13205 seconds
