Home » Archived » BIRT » Generate report via web page link
Generate report via web page link [message #368604] Sun, 14 June 2009 17:46 Go to next message
I am new to the Eclipse BIRT Report and like to confirm if clicking a link
on a web page can execute a BIRT reports dynamically using Eclipse BIRT
Reporting tool?
Re: Generate report via web page link [message #368606 is a reply to message #368604] Mon, 15 June 2009 00:35 Go to previous messageGo to next message
Originally posted by: johnw.innoventsolutions.com
Not withing Eclipse. But you can have a BIRT report sitting on a web
server and have a BIRT report engine or viewer running on there to run
reports.
John
> link on a web page can execute a BIRT reports dynamically using Eclipse
> BIRT Reporting tool?
Re: Generate report via web page link [message #990557 is a reply to message #368606] Thu, 13 December 2012 02:15 Go to previous messageGo to next message
I have created some BIRT reports. I want to access those reports from a web page where all those reports will be appear as hyperlinks.
I have used the syntax in href with <a> </a> tags as in attachment
Birt folder contains the report file inside WebApps folder
But when clicking on the hyperlink, the message is coming like no report design object found.
But whenever I am running the report individually in browser, it is showing through Birt Viewer
Could anybody suggest the solution
Re: Generate report via web page link [message #990753 is a reply to message #990557] Fri, 14 December 2012 00:50 Go to previous messageGo to next message
Try a double underscore '__' before report, rather than the single underscore you have.
Re: Generate report via web page link [message #990945 is a reply to message #990753] Sat, 15 December 2012 04:00 Go to previous messageGo to next message
Thanks . Its working.
Re: Generate report via web page link [message #991262 is a reply to message #990945] Tue, 18 December 2012 03:14 Go to previous messageGo to next message
Is it possible to certain columns from different dimensions and certain measures from the fact to prepare a report from a cube instead of dragging the whole cube...
Its like preparing a cube and then generating different reports from that cube by using different cols
Thanks & Regards
Re: Generate report via web page link [message #991358 is a reply to message #991262] Tue, 18 December 2012 12:25 Go to previous message
I'm not certain I'm understanding. If you're talking about creating a crosstab with only some of the dimensions and measures from a cube, rather than dragging the cube into your design, you can pull a crosstab from the palette and drag just the dimensions and measures you want to use into it. Let me know if I'm mistaken on what you're asking.
Previous Topic:Connection Pool in Birt
Next Topic:Height of Report Viewer embedded in iframe
Current Time: Sat Jul 26 10:51:01 EDT 2025
Powered by FUDForum. Page generated in 0.08285 seconds
