Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » NPE When Serializing with Texo
NPE When Serializing with Texo [message #990926] Fri, 14 December 2012 17:45 Go to next message
I'm trying to serialize a model as described here:
http://wiki.eclipse.org/Texo/XML_and_XMI_Serialization
I did make sure to "Touch" or initialize the model package. I'll first list the exception, then my test code, then my maven dependencies, then the model.
EXCEPTION:
java.lang.ExceptionInInitializerError
at com.example.texo.SerializationTest.serialize(SerializationTest.java:17)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:69)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:48)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.runners.ParentRunner.run(ParentRunner.java:292)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.getEncoding(XMLLoadImpl.java:314)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:122)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
at org.eclipse.emf.texo.utils.ModelUtils.readEPackagesFromFile(ModelUtils.java:343)
at com.example.texo.TexoModelPackage.initialize(TexoModelPackage.java:88)
at com.example.texo.TexoModelPackage.<clinit>(TexoModelPackage.java:66)
... 24 more
TEST CODE:package com.example.texo;
import static org.junit.Assert.*;
import java.io.StringWriter;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.emf.texo.xml.ModelXMLSaver;
import org.junit.Test;
public class SerializationTest {
@Test
public void serialize()
TexoModelPackage.initialize();
List<Object> modelObjects = new ArrayList<Object>();
modelObjects.add(new Configuration());
final ModelXMLSaver xmlSaver = new ModelXMLSaver();
xmlSaver.setSaveAsXMI(true);
xmlSaver.setObjects(modelObjects);
final StringWriter sw = new StringWriter();
xmlSaver.setWriter(sw);
xmlSaver.write();
String content = sw.toString();
assertNotNull(content);
MAVEN DEPENDENCIES:
<dependencies>
<!-- Logging -->
<dependency>
<groupId>ch.qos.logback</groupId>
<artifactId>logback-classic</artifactId>
<version>1.0.7</version>
</dependency>
<!-- Modeling -->
<dependency>
<groupId>org.eclipse.emf</groupId>
<artifactId>org.eclipse.emf.common</artifactId>
<version>2.8.0-v20120911-0500</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.ecore.xmi</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.ecore</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.texo.xml</artifactId>
<version>0.1.0-v201210251502</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.texo</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.texo.server</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.texo.json</artifactId>
</dependency>
<!-- Testing -->
<dependency>
<groupId>org.hamcrest</groupId>
<artifactId>hamcrest-all</artifactId>
<version>1.3</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.9</version>
<scope>test</scope>
<exclusions>
<exclusion>
<artifactId>hamcrest-core</artifactId>
</exclusion>
</exclusions>
</dependency>
</dependencies>
MODEL
<ecore:EPackage xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="texo" nsURI="http://texo.example.com" nsPrefix="texo">
<eClassifiers xsi:type="ecore:EClass" name="Configuration">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="fileName" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"
defaultValueLiteral="nameofthefile" unsettable="true"/>
</eClassifiers>
</ecore:EPackage>
Thoughts?
TIA,
- Ole
Re: NPE When Serializing with Texo [message #990929 is a reply to message #990926] Fri, 14 December 2012 18:11 Go to previous messageGo to next message
Hi Ole,
Another user has also reported this issue. I changed the error message so it is more descriptive (for now).
In the generated code there should also be an ecore file in that same java package. Can you check if this ecore file is
there and is also present in the output directory (bin/build)? And that it is present in any other location where you
use your runtime code (for example when packaging it in a jar)?
gr. Marton
On 12/14/2012 11:45 PM, Ole Ersoy wrote:
> EXCEPTION:
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> ... 24 more
> @Test
> xmlSaver.write();
> MAVEN DEPENDENCIES:
> <dependencies>
> <!-- Logging -->
> <dependency>
> </dependency>
> <!-- Modeling -->
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <!-- Testing -->
> <dependency>
> <scope>test</scope>
> </dependency>
> <dependency>
> <scope>test</scope>
> <exclusions>
> <exclusion>
> </exclusion>
> </exclusions>
> </dependency>
> </dependencies>
> MODEL
> </eClassifiers>
> </ecore:EPackage>
> Thoughts?
> TIA,
> - Ole
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: NPE When Serializing with Texo [message #990936 is a reply to message #990929] Fri, 14 December 2012 23:14 Go to previous messageGo to next message
Hi Martin,
Got it - Thanks! For others reading the thread and using Maven - the file was generating into the "src/main/java", but neither "mvn eclipse:eclipse", nor "mvn test" was "seeing" it, since Maven's default behavior is to archive only .java files from src/main/java. It expects other resources to be in "src/main/resources". I fixed it by adding this:
<resources>
<resource>
<directory>src/main/java</directory>
<includes>
<include>com/example/texo/texo.ecore</include>
</includes>
</resource>
</resources>
For details see:
http://maven.apache.org/plugins/maven-resources-plugin/examples/include-exclude.html
http://stackoverflow.com/questions/4509309/in-maven-how-can-i-include-non-java-src-files-in-the-same-place-in-the-output-ja
Thanks again for making Texo. It's brilliant,
- Ole
On 12/14/2012 05:11 PM, Martin Taal wrote:
> Hi Ole,
> In the generated code there should also be an ecore file in that same java package. Can you check if this ecore file is there and is also present in the output directory (bin/build)? And that it is present in any other location where you use your runtime code (for example when packaging it in a jar)?
> gr. Marton
>> Hi,
>> EXCEPTION:
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> ... 24 more
>> @Test
>> xmlSaver.write();
>> MAVEN DEPENDENCIES:
>> <dependencies>
>> <!-- Logging -->
>> <dependency>
>> </dependency>
>> <!-- Modeling -->
>> <dependency>
>> </dependency>
>> <dependency>
>> </dependency>
>> <dependency>
>> </dependency>
>> <dependency>
>> </dependency>
>> <dependency>
>> </dependency>
>> <dependency>
>> </dependency>
>> <dependency>
>> </dependency>
>> <!-- Testing -->
>> <dependency>
>> <scope>test</scope>
>> </dependency>
>> <dependency>
>> <scope>test</scope>
>> <exclusions>
>> <exclusion>
>> </exclusion>
>> </exclusions>
>> </dependency>
>> </dependencies>
>> MODEL
>> <?xml version="1.0" encoding="UTF-8"?>
>> </eClassifiers>
>> </ecore:EPackage>
>> Thoughts?
>> TIA,
>> - Ole
Re: NPE When Serializing with Texo [message #990970 is a reply to message #990936] Sat, 15 December 2012 13:43 Go to previous message
Thanks Ole for the answer, will add to the wiki!
gr. Martin
On 12/15/2012 05:14 AM, Ole Ersoy wrote:
> Hi Martin,
> <resources>
> <resource>
> <includes>
> </includes>
> </resource>
> </resources>
> For details see:
> - Ole
>> Hi Ole,
>> gr. Marton
>>> Hi,
>>> EXCEPTION:
>>> ... 24 more
>>> @Test
>>> xmlSaver.write();
>>> MAVEN DEPENDENCIES:
>>> <dependencies>
>>> <!-- Logging -->
>>> <dependency>
>>> </dependency>
>>> <!-- Modeling -->
>>> <dependency>
>>> </dependency>
>>> <dependency>
>>> </dependency>
>>> <dependency>
>>> </dependency>
>>> <dependency>
>>> </dependency>
>>> <dependency>
>>> </dependency>
>>> <dependency>
>>> </dependency>
>>> <dependency>
>>> </dependency>
>>> <!-- Testing -->
>>> <dependency>
>>> <scope>test</scope>
>>> </dependency>
>>> <dependency>
>>> <scope>test</scope>
>>> <exclusions>
>>> <exclusion>
>>> </exclusion>
>>> </exclusions>
>>> </dependency>
>>> </dependencies>
>>> MODEL
>>> </eClassifiers>
>>> </ecore:EPackage>
>>> Thoughts?
>>> TIA,
>>> - Ole
The Netherlands
Previous Topic:Access to the XTend2 Template Files.
Next Topic:Multi Java Annotations in the model
Current Time: Wed Jul 23 12:31:21 EDT 2025
Powered by FUDForum. Page generated in 0.26832 seconds
