Home » Eclipse Projects » Nebula » Announcement: CalendarCombo EOL
Announcement: CalendarCombo EOL [message #990897] Fri, 14 December 2012 12:30
LS,
The Nebula team informs you of the pending termination of the CalendarCombo widget [1]. Most of the functions supported by this widget are now supplied by the SWT DateTime widget [2]. Advanced date capabilities can be obtained from the Nebula CDateTime widet [3].
On march 31 2013, The CalendarCombo widget will be moved to the Nebula Incubation project were it will stay as an unsupported widget for three months until it is archived on june 30 2013.
Please change you code to use the SWT DateTime widget or the Nebula CDateTime widget.
The widget was created by Emil Crumhorn. Emil, thanks!
For more information see the discussion in the Nebula Dev mailing list [4].
Wim Jongman
Nebula Project
"Considering it's lived for more than 10 years I'd say it's had a very good run!"
- Emil Crumhorn
[1] http://eclipse.org/nebula/widgets/calendarcombo/calendarcombo.php
[2] http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Freference%2Fapi%2Forg%2Feclipse%2Fswt%2Fwidgets%2FDateTime.html
[3] http://www.eclipse.org/nebula/widgets/cdatetime/cdatetime.php
[4] http://dev.eclipse.org/mhonarc/lists/nebula-dev/msg02338.html
Previous Topic:[GanttChart] Custom Text Formating Parameters
Next Topic:How to programmatically save a picture of a Gantt
Current Time: Tue Sep 23 20:50:12 EDT 2025
Powered by FUDForum. Page generated in 0.05561 seconds
