Home » Newcomers » Newcomers » Eclipse CFScript Syntax Highlighting Bug
Eclipse CFScript Syntax Highlighting Bug [message #990870] Fri, 14 December 2012 10:33 Go to next message
I have the eclipse juno service release 1 with CFeclipse.
The syntax coloring preferences are set, so that text is black and expressions in quotes are blue. When i use single quotes within CFScript, then after the closing quote all of the following code becomes blue. The code is correct, i tried it in dreamweaver, and all of the code was highlighted fine.
Someone has an answer?
Images attached:
- eclipse installation details
- syntax highlighting bug
  • Attachment: eclipse.jpg
    (Size: 177.80KB, Downloaded 150 times)
  • Attachment: eclipse2.jpg
    (Size: 92.97KB, Downloaded 158 times)
Re: Eclipse CFScript Syntax Highlighting Bug [message #990885 is a reply to message #990870] Fri, 14 December 2012 11:18 Go to previous message
CFEclipse isn't a project hosted at Eclipse so better you look for help
at their link: http://cfeclipse.org/index.cfm/help/
> Images attached:
Previous Topic:Eclipse 4.2 Garbled Text while scrolling
Next Topic:Cannot find plugin
Current Time: Sun Jul 27 14:43:56 EDT 2025
Powered by FUDForum. Page generated in 0.38265 seconds
