Home » Eclipse Projects » Eclipse Scout » Radiobutton group vertical aligned
Radiobutton group vertical aligned [message #990810] Fri, 14 December 2012 05:43 Go to next message
I have a radiobuttonGroup with three radiobuttons in it. The labels are rather long so I want the buttons to appear below each other in stead of next to each other.
Is it possible and if yes how to configure this.
Regards Bertin
Re: Radiobutton group vertical aligned [message #990834 is a reply to message #990810] Fri, 14 December 2012 06:40 Go to previous message
RadioButtonGroup<T> is a value Field and a composite Field.
This means you can configure your Grid in the RadioGroup as you would do for a GroupBox field.
Here a small example:
      @Order(30.0)
      public class RadioGroupBox extends AbstractRadioButtonGroup<Long> {
        protected int getConfiguredGridColumnCount() {
          return 1;
        protected int getConfiguredGridH() {
          return 3;
        protected String getConfiguredLabel() {
          return "Radio group label"; //XXX: use TEXTS.get(..)
        @Order(10.0)
        public class Value1Field extends AbstractRadioButton {
            return "Value1"; //XXX: use TEXTS.get(..)
          protected Object getConfiguredRadioValue() {
            return 1L;
          protected int getConfiguredGridW() {
            return 1;
        @Order(20.0)
        public class Value2Field extends AbstractRadioButton {
            return 1;
            return "Value2"; //XXX: use TEXTS.get(..)
            return 2L;
        @Order(30.0)
        public class Value3Field extends AbstractRadioButton {
            return 1;
            return "Value3"; //XXX: use TEXTS.get(..)
            return 3L;
index.php/fa/12711/0/
[Updated on: Fri, 14 December 2012 06:41] by Moderator
Previous Topic:Unable to locate secure storage module
Next Topic:AbstractSqlService.getSequenceNextval() specific to Oracle
Current Time: Thu Jul 24 19:27:35 EDT 2025
Powered by FUDForum. Page generated in 0.03316 seconds
