Home » Language IDEs » C / C++ IDE (CDT) » Undefined Reference to GMP(Building failed with GMP library in C project.)
Undefined Reference to GMP [message #990809] Fri, 14 December 2012 05:43 Go to next message
Hi all,
I want to build a project with GMP library.
However, I get errors when building my project.
Errors:-
/cygdrive/d/workspace-cpp/gmp/Debug/../src/Test.c:11: undefined reference to `__imp____gmpz_init'
/cygdrive/d/workspace-cpp/gmp/Debug/../src/Test.c:12: undefined reference to `__imp____gmpz_init'
/cygdrive/d/workspace-cpp/gmp/Debug/../src/Test.c:13: undefined reference to `__imp____gmpz_init'
/cygdrive/d/workspace-cpp/gmp/Debug/../src/Test.c:15: undefined reference to `__imp____gmpz_set_str'
/cygdrive/d/workspace-cpp/gmp/Debug/../src/Test.c:16: undefined reference to `__imp____gmpz_set_str'
/cygdrive/d/workspace-cpp/gmp/Debug/../src/Test.c:18: undefined reference to `__imp____gmpz_mul'
/cygdrive/d/workspace-cpp/gmp/Debug/../src/Test.c:19: undefined reference to `__imp____gmp_printf'
/cygdrive/d/workspace-cpp/gmp/Debug/../src/Test.c:22: undefined reference to `__imp____gmpz_clear'
/cygdrive/d/workspace-cpp/gmp/Debug/../src/Test.c:23: undefined reference to `__imp____gmpz_clear'
/cygdrive/d/workspace-cpp/gmp/Debug/../src/Test.c:24: undefined reference to `__imp____gmpz_clear'
I'm using Cygwin to build my C project.
I am able to compile my class at Command Prompt with :-
gcc -o test test.c -lgmp
And it success to generate the result perfectly.
Any solution for me to solve it or any reference link I can investigate how to use GMP in Eclipse?
Is it maybe my own make.exe code incorrectly?
Thanks for replied first.
Re: Undefined Reference to GMP [message #990884 is a reply to message #990809] Fri, 14 December 2012 11:12 Go to previous messageGo to next message
On 12/14/2012 07:56 AM, Leong Hui Yap wrote:
> Hi all,
> Errors:-
You need to add the gmp library on the Paths and Symbols tab of your
project properties so that Eclipse can include the -lgmp to the command
line used to launch gcc.
Re: Undefined Reference to GMP [message #991031 is a reply to message #990884] Mon, 17 December 2012 01:47 Go to previous messageGo to next message
Thanks so much.
After I included the gmp lib into project.
Another errors was occurred.
Can you teach me how to solve this too?
**** Build of configuration Debug for project gmp ****
D:\workspace-cpp\gmp\make all
Building file: ../src/Test.c
Invoking: Cygwin C Compiler
gcc -I"D:\workspace-cpp\gmp\lib" -I"D:\workspace-cpp\gmp\src" -O0 -g3 -Wall -c -fmessage-length=0 -MMD -MP -MF"src/Test.d" -MT"src/Test.d" -o "src/Test.o" "../src/Test.c"
Finished building: ../src/Test.c
Building target: gmp.exe
Invoking: Cygwin C Linker
gcc -o "gmp.exe" ./src/Test.o -l"D:/workspace-cpp/gmp/lib/libgmp.a" -l"D:/workspace-cpp/gmp/lib/libgmp.la"
/usr/lib/gcc/i686-pc-cygwin/4.3.4/../../../../i686-pc-cygwin/bin/ld: cannot find -lD:/workspace-cpp/gmp/lib/libgmp.a
/usr/lib/gcc/i686-pc-cygwin/4.3.4/../../../../i686-pc-cygwin/bin/ld: cannot find -lD:/workspace-cpp/gmp/lib/libgmp.la
collect2: ld returned 1 exit status
make: *** [gmp.exe] Error 1
**** Build Finished ****
Thanks you.
Re: Undefined Reference to GMP [message #991163 is a reply to message #991031] Mon, 17 December 2012 10:18 Go to previous messageGo to next message
On 12/17/2012 12:47 AM, Leong Hui Yap wrote:
> Thanks so much. After I included the gmp lib into project.
> D:\workspace-cpp\gmp\make all Building file: ../src/Test.c
> Thanks you.
You don't define the library with the full path. You just need to add
gmp as the library name. The linker should then find the correct
library file.
Re: Undefined Reference to GMP [message #991709 is a reply to message #991163] Wed, 19 December 2012 21:52 Go to previous message
Yes, it worked like a charm.
Thanks David very much Laughing
Previous Topic:Eclipse debugger stops at dl_main
Next Topic:Error message from debugger back end
Current Time: Fri Jul 25 08:37:48 EDT 2025
Powered by FUDForum. Page generated in 0.04911 seconds
