generate genmodel from schema xml [message #633592] |
Mon, 18 October 2010 09:41  |
Hello everybody.
I tried to generate a genmodel from schema xml of ygraph.
You can find them at this adress :
http://www.yworks.com/en/downloads.html#yEd.
(in the GraphML - yFiles for Java XML Extension part)
the problem is that the file ygraphml.xsd, 2 type are redeine a second times,
For exemple :
in the file graphml.xsd we can find :
<xs:redefine schemaLocation="graphml-structure.xsd">
<xs:attributeGroup name="key.extra.attrib">
<xs:annotation>
<xs:documentation source="http://graphml.graphdrawing.org/"
xml:lang="en">
Redefinition of file graphml-structure.xsd.
Extends the attribute group key.extra.attrib (which takes
part in the attribute list of <key>) by adding the
attribute group key.attributes.attrib which is defined below.
</xs:documentation>
</xs:annotation>
<xs:attributeGroup ref="key.extra.attrib" />
<xs:attributeGroup ref="key.attributes.attrib" />
</xs:attributeGroup>
so this file refefine the type "key.extra.attrib"
And in the file ygraphml.xsd :
<xs:redefine schemaLocation="graphml.xsd">
<xs:annotation>
<xs:documentation>
<p>Extends the attribute group key.extra.attrib (which takes
part in
attribute yfiles.type
</p>
</xs:documentation>
</xs:annotation>
<xs:attributeGroup ref="yfiles.foldertype.attrib" />
the same attribute : "key.extra.attrib" is redefined a second time.
notice that an other attribute is redefined twice time : "node.extra.attrib"
So whan I try to generate an genmodel file from this xsd, I have this mistake :
Error: XSD: The attribute group may not be circularly defined ... :
IS it a mistake of EMF or of yworks that I can't generate the genmodel. eclipse said to me that all schemas are valide. And I don't modified them.
How can I resolve this problem?
Jérémie
FUDForum. Page generated in 0.08394 seconds
