Home » Eclipse Projects » EGit / JGit » Egit well installed, but no GIT menu(I can't use EGit whatever I want to do (no team, no preferences item))
Egit well installed, but no GIT menu [message #990171] Tue, 11 December 2012 04:37 Go to next message
Hi All,
I would like to use EGit in my project configuration management.
I am currently using the GIT command line interface, but I am sure I will be more efficient by using this plugin.
In Eclipse, the Egit plugin seems to be well installed (according to the Eclipse diagnostic), but whatever the menu I select to configure Egit or my project to be managed with Egit, I can't find any EGit menu item.
In Project/Team/Share project: Only CVS is present
In Project/Import: Only CVS is possible
In Preferences, in Team synchronizing menus, always CVS and no GIT.
Could you help me, please ?
Gwenn
Re: Egit well installed, but no GIT menu [message #990277 is a reply to message #990171] Tue, 11 December 2012 12:03 Go to previous messageGo to next message
Click "About Eclipse > Installation Details > Plug-ins" and check if the jgit and egit bundles are installed,
you should have at least:
org.eclipse.egit
org.eclipse.egit.core
org.eclipse.egit.ui
org.eclipse.jgit
all these plugins should come from the same release.
Also you may check the error log for errors mentioning egit or jgit.
Re: Egit well installed, but no GIT menu [message #990562 is a reply to message #990277] Thu, 13 December 2012 02:58 Go to previous messageGo to next message
Hi Matthias
I have checked what you mentioned and all are ok (I didn't installed the JGit, because I don't use Java.)
The version is
Eclipse EGit 2.1.0.201209190230-r org.eclipse.egit.feature.group Eclipse EGit
For the error logs, where I can get them ?
Gwenn
Re: Egit well installed, but no GIT menu [message #990565 is a reply to message #990562] Thu, 13 December 2012 03:28 Go to previous messageGo to next message
EGit can't work without JGit, JGit is a Java library implementing git and EGit is using that to provide a UI and integrate it with the Eclipse Team framework.
Re: Egit well installed, but no GIT menu [message #990762 is a reply to message #990565] Fri, 14 December 2012 02:42 Go to previous messageGo to next message
Same behavior: I can't see any EGit menu whereever they could be
Gwenn
Re: Egit well installed, but no GIT menu [message #992261 is a reply to message #990762] Fri, 21 December 2012 03:28 Go to previous message
Hi Every body!
After an update request for Egit and a new installation of these plugins, all works fine.
Thanks for your support
Gwenn
Previous Topic:How to untrack already tracked files
Next Topic:Delete Added Line fails to delete LF at end of file
Current Time: Sat Jul 26 23:20:02 EDT 2025
Powered by FUDForum. Page generated in 0.07961 seconds
