Acces QVT-O transformations from other folders or plug-ins [message #990611] |
Thu, 13 December 2012 07:27  |
is there a way to access (call) a QVT-O transformation from within another transformation although the accessed transformation is in another directory or plug-in? I'd like to do something like the following
transformation MyCallingTransformation(inout model:MyModel)
access transformation MyCalledTransformation(inout model:MyModel);
while MyCalledTransformation is in another directory in the Eclipse workspace and in another plug-in project. Can I use an URI like 'platform:/plugin/de.xyz.myplugin/transforms/MyCalledTransformation.qvto' or '../../de.xyz.myplugin/transforms/MyCalledTransformation.qvto' to access the transformation?
Dietrich
Re: Acces QVT-O transformations from other folders or plug-ins [message #991527 is a reply to message #990722] |
Wed, 19 December 2012 11:57   |
Hi Ed,
thank you, that was the right hint. Now, I have another problem:
I'm trying to call a transformation within another transformation, but there seems to be no way to create an input model for the called transformation which is not empty, but contains a certain set of objects. My calling transformation looks something like the following:
import MyModel2Ecore;
modeltype Mapping uses ...
transformation CallingTransformation(inout inputMapping:Mapping)
access transformation MyModel2Ecore(inout inputMapping:Mapping)
main()
var inputObject:= inputMapping.rootObjects()![SomeRoot].applications->select(newInput: SomeType| newInput.name = 'Some Name')![SomeOtherType];
// 1. idea: create an empty model and add the desired objects
//var model : Mapping := design2PatternMapping.createEmptyModel().oclAsType(Mapping);
// inputObject cannot be added to the empty model or set to be the root of the model
// 2. idea: copy the given model end remove all elements, but the desired ones
var model : Mapping := design2PatternMapping.copy().oclAsType(Mapping);
// this seems to remove the root including all contained elements :-(
// I only want to replace the root with another object that is contained in the root
model.removeElement(model.rootObjects()![PatternApplications]);
// call the transformation with the selected input object
var retC := (new MyModel2Ecore(model))->transform();
I wanted to use this calling transformation for debugging purposes. I want to debug the called transformation which is usually called by Java code with a selected set of objects as input model. When debugging the Java code of the plug-in, I cannot step into the executed QVT code for debugging. So, I decided to directly run the transformation and to use this calling transformation to select the input.
Dietrich
Re: Acces QVT-O transformations from other folders or plug-ins [message #991536 is a reply to message #991527] |
Wed, 19 December 2012 12:15  |
Sorry; no ideas other than to dive into the QVTo tooling code to find
out what is really happening at the root.
Ed Willink
On 19/12/2012 16:57, Dietrich Travkin wrote:
> Hi Ed,
> main()
> var inputObject:=
> the desired ones
> elements :-(
> input.
> Regards,
> Dietrich
FUDForum. Page generated in 0.27688 seconds
