Home » Modeling » QVT-OML » Acces QVT-O transformations from other folders or plug-ins
Acces QVT-O transformations from other folders or plug-ins [message #990611] Thu, 13 December 2012 07:27 Go to next message
is there a way to access (call) a QVT-O transformation from within another transformation although the accessed transformation is in another directory or plug-in? I'd like to do something like the following
transformation MyCallingTransformation(inout model:MyModel)
	access transformation MyCalledTransformation(inout model:MyModel);
while MyCalledTransformation is in another directory in the Eclipse workspace and in another plug-in project. Can I use an URI like 'platform:/plugin/de.xyz.myplugin/transforms/MyCalledTransformation.qvto' or '../../de.xyz.myplugin/transforms/MyCalledTransformation.qvto' to access the transformation?
Dietrich
Re: Acces QVT-O transformations from other folders or plug-ins [message #990722 is a reply to message #990611] Thu, 13 December 2012 11:49 Go to previous messageGo to next message
The grammar suggests access uses an ordinary package name (a
transformation is both a package and a class).
In
\GIT\org.eclipse.qvto\tests\org.eclipse.m2m.tests.qvt.oml\parserTestData\models\transf_inheritance\A.qvto
you will find an example.
import models.transf_inheritance.Lib;
import models.transf_inheritance.nested.A;
modeltype ECORE uses ecore('http://www.eclipse.org/emf/2002/Ecore');
transformation A(inout m:ECORE)
extends transformation models::transf_inheritance::nested::A(inout
m:ECORE)
-- implicit library import with extension semantics of the 'Lib'
main() {
m.objectsOfType(ECORE::EClass)->forEach(c) { addSuffix(c); };
helper addSuffix(inout n : ECORE::ENamedElement) {
n.name := addSuffix(n.name);
return;
HTH
Ed Willink
On 13/12/2012 16:21, Dietrich Travkin wrote:
> Hello,
> Best regards,
> Dietrich
Re: Acces QVT-O transformations from other folders or plug-ins [message #991527 is a reply to message #990722] Wed, 19 December 2012 11:57 Go to previous messageGo to next message
Hi Ed,
thank you, that was the right hint. Now, I have another problem:
I'm trying to call a transformation within another transformation, but there seems to be no way to create an input model for the called transformation which is not empty, but contains a certain set of objects. My calling transformation looks something like the following:
import MyModel2Ecore;
modeltype Mapping uses ...
transformation CallingTransformation(inout inputMapping:Mapping)
	access transformation MyModel2Ecore(inout inputMapping:Mapping)
	main()
		var inputObject:= inputMapping.rootObjects()![SomeRoot].applications->select(newInput: SomeType| newInput.name = 'Some Name')![SomeOtherType];
		// 1. idea: create an empty model and add the desired objects
		//var model : Mapping := design2PatternMapping.createEmptyModel().oclAsType(Mapping);
		// inputObject cannot be added to the empty model or set to be the root of the model
		// 2. idea: copy the given model end remove all elements, but the desired ones
		var model : Mapping := design2PatternMapping.copy().oclAsType(Mapping);
		// this seems to remove the root including all contained elements :-(
		// I only want to replace the root with another object that is contained in the root
		model.removeElement(model.rootObjects()![PatternApplications]);
		// call the transformation with the selected input object
		var retC := (new MyModel2Ecore(model))->transform();
I wanted to use this calling transformation for debugging purposes. I want to debug the called transformation which is usually called by Java code with a selected set of objects as input model. When debugging the Java code of the plug-in, I cannot step into the executed QVT code for debugging. So, I decided to directly run the transformation and to use this calling transformation to select the input.
Dietrich
Re: Acces QVT-O transformations from other folders or plug-ins [message #991536 is a reply to message #991527] Wed, 19 December 2012 12:15 Go to previous message
Sorry; no ideas other than to dive into the QVTo tooling code to find
out what is really happening at the root.
Ed Willink
On 19/12/2012 16:57, Dietrich Travkin wrote:
> Hi Ed,
> main()
> var inputObject:=
> the desired ones
> elements :-(
> input.
> Regards,
> Dietrich
Previous Topic:l'utilisation de qvt
Next Topic:For QVT-O EObject seems not to be supertype of EModelElement
Current Time: Sun Jul 27 16:16:20 EDT 2025
Powered by FUDForum. Page generated in 0.03146 seconds
