Home » Language IDEs » Java Development Tools (JDT) » Performance with SearchEngine(Performance with SearchEngine. Provide any accessible classes, filtered by text typed.)
icon5.gif  Performance with SearchEngine [message #990603] Thu, 13 December 2012 06:55 Go to next message
I'm developing a plugin to create methods in my project.
I need provide all classes that can be accessible by a class that I'm editing.
I use the SearchEngine to find Classes to provide proposals, but if I define my research (scope) for "SOURCES | APPLICATION_LIBRARIES | REFERENCED_PROJECTS | SYSTEM_LIBRARIES" sometimes it's slowly or I get one "OutOfMemory". (Searching for CLASS_AND_INTERFACE | DECLARATIONS).
Researching how the eclipse is so fast in your researches I find that uses an "Index" (stored in '.metadata' of the 'workspace') and keep the results in memory.
I'm thinkin to keep the result of search "SYSTEM_LIBRARIES" (in the first request and exclude from the scope of research) in memory (static var in my plugin) and after that, filter this static list by the text typed, I'll do this in one class that extends TypeNameMatchRequestor. Any way, if my project has a lot of libraries my research still slow.
Is there a way to use "indexes" of the eclipse?
You know another solution for this case? (Provide any accessible classes, filtered by text typed, quickly and safely).
Sometime I saw that is not recommended to use static variables in the plugin, I'll take issue with this "solution"?
Thanks.
Re: Performance with SearchEngine [message #990910 is a reply to message #990603] Fri, 14 December 2012 14:24 Go to previous message
When searching via the SearchEngine, you are implicitly using the indexes already.
I could imagine that slowness comes from the second phase of searching where index matches are located precisely inside Java code.
You may want to step through org.eclipse.jdt.internal.core.search.BasicSearchEngine.findMatches(SearchPattern, SearchParticipant[], IJavaSearchScope, SearchRequestor, IProgressMonitor) to see where the time is consumed.
Perhaps you'll find a faster solution by looking at how Open Type et al are doing the search, see org.eclipse.jdt.internal.ui.dialogs.FilteredTypesSelectionDialog.
HTH,
Stephan
Previous Topic:How to detect what is causing excessive Autobuild
Next Topic:eclipse crashes during startup with NullPointerException
Current Time: Sat Jul 26 08:55:07 EDT 2025
Powered by FUDForum. Page generated in 0.02661 seconds
