swing on views [message #98942] |
Thu, 21 July 2005 07:03  |
Originally posted by: newshuntertr.hotmail.com
can i use swing components on ViewPart? it is disabled to drag&drop a
swing component from toolbar to the viewpart on VE.
-News Hunter-
Re: swing on views [message #99247 is a reply to message #99187] |
Fri, 22 July 2005 10:34  |
Originally posted by: jdstinto.us.ibm.com
Make sure you create a plugin project to try the below example out. It
seems like it works, but I didn't get a chance to play with it too much.
There a two ways to use the viewer, let it create its own combo, or
create a combo and give it to him. Then you just add objects like a
list and it will try to figure out how to display them for you.
Hope that helps!
-Jon
> i need combo items as an object not just a string. like swing combo uses
> renderer for its data object i will need viewer property of jface as rich
> said. it is too hard to find an example about comboviewer.
> On Thu, 21 Jul 2005 11:21:44 -0400, Jonathan Stinton wrote:
>>Not sure I understand what you mean by "value feature." Neither JComboBox
>>nor SWT Combo has a value (at least by that name). There is also a CCombo
>>box that is in the SWT Custom library. But that is very similiar to the
>>others.
>>If you could elaborate a little more on the methods you use from Swing I
>>might be able to be of more assistance.
>>Thanks,
>>Jon
try this out:
import org.eclipse.jface.viewers.ComboViewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Combo;
import org.eclipse.swt.widgets.Shell;
public class ComboTest {
private Shell sShell = null;
private Combo combo = null;
private ComboViewer myViewer = null;
* This method initializes sShell
private void createSShell() {
sShell = new Shell();
sShell.setText("Shell");
createCombo();
sShell.setSize(new Point(300, 200));
* This method initializes combo
private void createCombo() {
combo = new Combo(sShell, SWT.NONE);
combo.setBounds(new org.eclipse.swt.graphics.Rectangle(67,53,88,36));
myViewer = new ComboViewer(combo);
myViewer.add("Text");
myViewer.add(new Integer(9));
Re: swing on views [message #609161 is a reply to message #98942] |
Thu, 21 July 2005 09:10  |
Currently you must use SWT controls for RCP applications. We do not yet
have any wrapper feature that will allow the use of Swing or AWT on top
of them. The same applies for straight SWT apps.
Jon
Re: swing on views [message #609166 is a reply to message #98986] |
Thu, 21 July 2005 10:00  |
some swt components limit me so much. for example combo has just text and
index feature. i need also value feature like swing component has. can i
find any swt component that has more features?
> have any wrapper feature that will allow the use of Swing or AWT on top of
> Jon
-News Hunter-
Re: swing on views [message #609169 is a reply to message #99015] |
Thu, 21 July 2005 11:21  |
JComboBox nor SWT Combo has a value (at least by that name). There is
also a CCombo box that is in the SWT Custom library. But that is very
similiar to the others.
Jon
>>Thanks,
>>Jon
> -News Hunter-
Re: swing on views [message #609170 is a reply to message #99015] |
Thu, 21 July 2005 11:24  |
If you are in an RCP app, you should have JFace available, in that case
you could try the ComboViewer. That works on content providers instead
of a list of strings.
>>Thanks,
>>Jon
> -News Hunter-
Rich Kulp
Re: swing on views [message #609176 is a reply to message #99074] |
Fri, 22 July 2005 07:55  |
as i examined api it seems comboviewer will solve my problem.where can i
find an example about its usage?
> you could try the ComboViewer. That works on content providers instead of
> a list of strings.
-News Hunter-
Re: swing on views [message #609177 is a reply to message #99059] |
Fri, 22 July 2005 07:57  |
> others.
> Jon
-News Hunter-
Re: swing on views [message #609181 is a reply to message #99187] |
Hope that helps!
-Jon
>>others.
>>Thanks,
>>Jon
try this out:
createCombo();
FUDForum. Page generated in 0.52207 seconds
