Home » Modeling » EMF » ECrossReferenceAdapter missing links
ECrossReferenceAdapter missing links [message #988840] Mon, 03 December 2012 07:19 Go to next message
I noticed somewhat strange during the usage of the ECrossReferenceAdapter, maybe someone can give me a hint on how to solve this problem.
My Situation:
I have 3 Models, Model A, B and AB (adapter is registered for the ResourceSet where the modelElements of AB life, i have atm 3 ResourceSets, one for each model);
A and B are models on their own, and AB is some kind of link-model to link elements from A and B.
So an Element from AB has a reference to one element of A and also to B.
Asking the inverses from an Element in Model B (which happens to be UML) gets me not only the inverses in Model B, but also the link from Model AB.
Asking the same for an Element in Model A only gets me the Elements from Model A, but none from the Model AB.
The notifications are generated so the adapter should somehow notice that something has change.
Could this be that in the ResourceSet-Implementation of UML it is somehow considered this case? But the Adapter is registered for the linkmodel ... so why doesn't he know the inverse from model A?
I tried to get a look into the ResourceSetImpl for the UML-Stuff which was my only hinch.
Maybe someone of you some kind of idea.
Greetings Markus
Re: ECrossReferenceAdapter missing links [message #989217 is a reply to message #988840] Wed, 05 December 2012 04:31 Go to previous messageGo to next message
Ok after letting the Problem rest for a day and get a new view on it I found that, at the time the reference is set, it is a proxy.
Afterwards, after the resource (especially the eobject) is loaded, i have the "real" object, but in the CrossReferenceMap the inverse reference is stored for the proxy, so that I don't get the Inverse for the real thing...
Would now be the correct way to handle this to force that the proxy is resolved?
Greetings,
Markus
Re: ECrossReferenceAdapter missing links [message #989349 is a reply to message #989217] Wed, 05 December 2012 13:38 Go to previous messageGo to next message
Markus,
I would have expected that resolving a proxy would be handled by this:
protected void handleCrossReference(EReference reference,
Notification notification)
switch (notification.getEventType())
case Notification.RESOLVE:
case Notification.SET:
case Notification.UNSET:
EObject notifier = (EObject)notification.getNotifier();
EReference feature = (EReference)notification.getFeature();
if (!feature.isMany() || notification.getPosition() !=
Notification.NO_INDEX)
EObject oldValue = (EObject)notification.getOldValue();
if (oldValue != null)
inverseCrossReferencer.remove(notifier, feature, oldValue);
EObject newValue = (EObject)notification.getNewValue();
if (newValue != null)
inverseCrossReferencer.add(notifier, feature, newValue);
break;
> the real thing...
> resolved?
> Greetings, Markus
Re: ECrossReferenceAdapter missing links [message #989841 is a reply to message #989349] Sat, 08 December 2012 05:15 Go to previous messageGo to next message
That's the part that bugs me... I just don't get it why there is an Object, with an eProxy uri.
Re: ECrossReferenceAdapter missing links [message #989860 is a reply to message #989841] Sat, 08 December 2012 11:31 Go to previous messageGo to next message
Markus,
Perhaps it can't be resolved? The debugger will be helpful...
Re: ECrossReferenceAdapter missing links [message #990064 is a reply to message #989860] Mon, 10 December 2012 12:10 Go to previous messageGo to next message
It can be resolved. The problem is (I think) I load these objects from a changing file (which i have to unload and load to get the updates).
Then at the set-time it is a different object as at the time I'm asking for the crossreferences ...
Greetings Markus
Re: ECrossReferenceAdapter missing links [message #990181 is a reply to message #990064] Tue, 11 December 2012 05:10 Go to previous messageGo to next message
Markus,
Comments below.
Until you access the model to cause the proxy to resolve (or use a
utility like EcoreUtil.resolveAll to force all proxies to resolve) you
should expect that cross referencer to hold information about the proxies.
I'm not sure I follow what you're trying to say... Is there still a
question?
> Greetings Markus
Re: ECrossReferenceAdapter missing links [message #990582 is a reply to message #990181] Thu, 13 December 2012 04:49 Go to previous message
Nope, there isn't a question anymore.
Thanks for your help! I really appreciate it.
Previous Topic:[emf compare] compare two jface treeviewer model data
Next Topic:[CDO] NPE at CDOObjectHistoryImpl.filter(CDOObjectHistoryImpl.java:58)
Current Time: Sun Nov 09 12:11:13 EST 2025
Powered by FUDForum. Page generated in 0.04541 seconds
