Home » Archived » Eclipse Process Manager (Stardust) » Build problems: time to update the project wiki?
Build problems: time to update the project wiki? [message #990464] Wed, 12 December 2012 10:38 Go to next message
Hi all,
I'm trying to build the project from source as described in the project wiki (http://wiki.eclipse.org/Stardust/Source_Code) and it looks like at least one new plugin has been added (deploy.jee) - maybe it's time to update the wiki page? Wink
After cloning deploy.jee.git to my local repo, I can get a little further in the build process, but it looks like there's a jar missing. I'm seeing the following error:
[WARNING] Missing POM for org.eclipse.stardust.engine:carnot-base:jar:9.9.9-SNAPSHOT
[ERROR] Internal error: java.lang.RuntimeException: Could not resolve project dependencies: Missing:
[ERROR] ----------
[ERROR] 1) org.eclipse.stardust.engine:carnot-base:jar:9.9.9-SNAPSHOT
[ERROR]
[ERROR] Try downloading the file manually from the project website.
[ERROR]
[ERROR] Then, install it using the command:
[ERROR] mvn install:install-file -DgroupId=org.eclipse.stardust.engine -DartifactId=carnot-base -Dversion=9.9.9-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
[ERROR]
[ERROR] Alternatively, if you host your own repository you can deploy the file there:
[ERROR] mvn deploy:deploy-file -DgroupId=org.eclipse.stardust.engine -DartifactId=carnot-base -Dversion=9.9.9-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
[ERROR]
[ERROR] Path to dependency:
[ERROR] 1) org.eclipse.stardust.modeling.engine:org.eclipse.stardust.ide.engine.base:pom:9.9.9-SNAPSHOT
[ERROR] 2) org.eclipse.stardust.engine:carnot-base:jar:9.9.9-SNAPSHOT
[ERROR]
[ERROR] ----------
[ERROR] 1 required artifact is missing.
[ERROR]
[ERROR] for artifact:
[ERROR] org.eclipse.stardust.modeling.engine:org.eclipse.stardust.ide.engine.base:pom:9.9.9-SNAPSHOT
[ERROR]
[ERROR] from the specified remote repositories:
[ERROR] eclipse-main (http://download.eclipse.org/releases/helios/, releases=false, snapshots=false),
[ERROR] eclipse-wtp (http://download.eclipse.org/webtools/downloads/drops/R3.2.3/R-3.2.3-20110217214612/repository/, releases=false, snapshots=false),
[ERROR] build.tools-repo (file://localhost/c:/Users/bbrodt/git/stardust/build.tools/lib, releases=true, snapshots=false),
[ERROR] stardust-3rdparty-repo (https://infinity.sungard.com/repository/ipp-3rd-party, releases=true, snapshots=false),
[ERROR] central (http://repo1.maven.org/maven2, releases=true, snapshots=false)
Also, I would like to be able to import the projects into an eclipse workspace for debugging. I am using the "Import existing Maven Projects" wizard to do this, but can't get past an importer error "Artifact ID is null" Unfortunately, the wizard won't tell me which artifact is causing this problem.
Oh, one more thing: is it possible to build this project with Indigo instead of Helios? It looks like there aren't any specific dependencies on 3.6.2
Any help here would be appreciated.
Bob
Re: Build problems: time to update the project wiki? [message #991142 is a reply to message #990464] Mon, 17 December 2012 08:40 Go to previous message
Hi Robert,
many thanks for your hint. I've updated the Wiki as follows:
  • Mentioned the deploy.jee Git repository
  • Updated "Building Stardust" section to emphasize which tasks are needed if you want to use your own Maven settings file instead of the one in build.tools/conf/m2
  • Added the section "Importing projects into Eclipse"
The second item should help you to fix your build issue. But let me explain this in short: unfortunately we have two dependency management systems, namely Maven and Ivy. The build process is prepared to use the Maven settings file which is located at build.tools/conf/m2. If you want to use the user or the global Maven settings file then you have to provide this as a property in build.tools/etc/private.properties.
Sorry for the inconvenience and appreciate your patience.
Sven
Previous Topic:Starting process using JMS Trigger
Next Topic:Stardust execution issue in Linux
Current Time: Sun Jul 27 14:28:10 EDT 2025
Powered by FUDForum. Page generated in 0.02744 seconds
