Re: Virtual Node Factory for classification of Nodes [message #991444 is a reply to message #991278] |
Wed, 19 December 2012 03:10   |
Something else, which I don't know if it's applicable or not, but it could be very helpful if you try to make it while developing 0.7
When you have errors in the "sdef" file, you can only know it by opening the "sdef" and noticing the error red flag, but in the eclipse project explorer, you don't find an error red flag on the "sdef" file as a source file to the project.
In short words, when a java file has some errors, it has red flag in the project explorer, but when an "sdef" file has some errors, it doesn't have any red flags in the project explorer. (that's really confusing sometimes)
Re: Virtual Node Factory for classification of Nodes [message #991481 is a reply to message #991444] |
Wed, 19 December 2012 07:40  |
Quote:I'd recommend adding some guidelines like these to the migration guide.
Adding more guidance is always possible, but first I need to get a better understanding about what wasn't obvious. What steps did you initially follow to update your Sapphire environment?
Quote:When you have errors in the "sdef" file, you can only know it by opening the "sdef" and noticing the error red flag, but in the eclipse project explorer, you don't find an error red flag on the "sdef" file as a source file to the project.
There is an enhancement request tracking this need, but as with all such items, there isn't enough time for everything. Some day.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=329080
My general migration advice is to avoid the temptation of going solely by errors. Some of the migration tasks will advertise themselves with errors, but many will not. I recommend going through the migration guide section-by-section and seeing if the stated case applies to your code. This approach will minimize the risk of long debugging sessions stemming from missed migration steps.
- Konstantin
[Updated on: Wed, 19 December 2012 07:40] by Moderator
FUDForum. Page generated in 0.10150 seconds
