Home » Modeling » EMF » [TENEO] Lazy Loading with UML(Persisting UML with Teneo)
[TENEO] Lazy Loading with UML [message #990248] |
Tue, 11 December 2012 10:25  |
I want to store UML model in a postgres DB using Teneo.
No problem with db configuration.
But I meet problems when I retrieve datas. For example, I create a Package, a subPackage and a Class in this subpackage.
All is persisted but when I retrieve the top package, childs are not found.
Here is my code :
public class AppTest extends TestCase {
private SessionFactory sessionFactory;
protected void setUp() throws Exception {
final Properties props = new Properties();
props.setProperty(Environment.DRIVER, "org.postgresql.Driver");
props.setProperty(Environment.USER, "postgres");
props.setProperty(Environment.URL, "jdbc:postgresql://127.0.0.1:5432/teneoumllazy");
props.setProperty(Environment.PASS, "midix");
props.setProperty(Environment.DIALECT, org.hibernate.dialect.ProgressDialect.class.getName());
props.setProperty("hibernate.show_sql", "true");
props.setProperty("teneo.naming.default_id_column", "uuid");
props.setProperty(PersistenceOptions.ALWAYS_VERSION, "false");
// props.setProperty(PersistenceOptions.FORCE_LAZY, "true");
props.setProperty(PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT, "ALL");
String hbName = "database";
final HbDataStore hbds = HbHelper.INSTANCE.createRegisterDataStore(hbName);
hbds.setDataStoreProperties(props);
hbds.setEPackages(new EPackage[] { EcorePackage.eINSTANCE, UMLPackage.eINSTANCE });
try {
hbds.initialize();
} finally {
// print the generated mapping
// System.err.println(hbds.getMappingXML());
sessionFactory = hbds.getSessionFactory();
Session session = sessionFactory.openSession();
Transaction tx = session.getTransaction();
tx.begin();
org.eclipse.uml2.uml.Package ePackage = UMLFactory.eINSTANCE.createPackage();
ePackage.setName("com.test");
org.eclipse.uml2.uml.Package ePackage2 = UMLFactory.eINSTANCE.createPackage();
ePackage2.setName("middle");
ePackage.getPackagedElements().add(ePackage2);
org.eclipse.uml2.uml.Class clazz = UMLFactory.eINSTANCE.createClass();
clazz.setName("Test");
ePackage2.getPackagedElements().add(clazz);
session.persist(ePackage);
tx.commit();
session.close();
public void testApp() {
tx.begin();
Query query = session.createQuery("from Package p where name = 'com.test'");
org.eclipse.uml2.uml.Package ePackage = (org.eclipse.uml2.uml.Package)query.uniqueResult();
System.out.println(ePackage.getName());
System.out.println("size : " + ePackage.getPackagedElements().size());
session.close();
The package name is displayed correctly but the child size is 0.
The problem is same if I uncomment props.setProperty(PersistenceOptions.FORCE_LAZY, "true");
Can someone help me?
Best regards
Attachment: AppTest.java
(Size: 2.86KB, Downloaded 246 times)
Re: [TENEO] Lazy Loading with UML [message #990334 is a reply to message #990248] |
Tue, 11 December 2012 17:03   |
Hi Michel,
I tested this and the reason that this happens is because of multiple inheritance. The Package inherits from namespace,
packageableelements and templateableelement. The packageelement efeature references the packageableelements type.
However, in a rdb/orm environment, multiple inheritance is not supported fully. In this case the Package type will not
be persisted in the packageableelements table but in the namespace table. So the packageableelements table remains empty
and the packageableelements efeature does not have content.
See here for more information:
http://wiki.eclipse.org/Teneo/Hibernate/ModelRelational/Inheritance_Mapping#Multiple_Inheritance_Support
gr. Martin
On 12/11/2012 07:13 PM, Michel Dirix wrote:
> Here is my code :
> @Override
> try {
> hbds.initialize();
> } finally {
> tx.begin();
> tx.commit();
> session.close();
> tx.begin();
> session.close();
> Best regards
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [TENEO] Lazy Loading with UML [message #990701 is a reply to message #990460] |
Wed, 12 December 2012 17:03  |
Hi Michael,
The solution is to influence the primary parent eclass, but you are stuck if other ereferences refer to the other super
eclasses...
It is the way orm tools work I am afraid, multiple inheritance is only supported partially.
gr. Martin
On 12/12/2012 04:29 PM, Michel Dirix wrote:
> Hi Martin,
> Thanks for your answer.
> So I have to find the good INHERITANCE_MAPPING or modify the hibernate xml file?
> I tried JOINED and TABLE_PER_CLASS without success, I have errors when the xml file is loaded.
> Best regards
> Michel Dirix
The Netherlands
Current Time: Sat Jul 26 18:54:14 EDT 2025
Powered by FUDForum. Page generated in 0.04150 seconds
