Home » Modeling » TMF (Xtext) » signer information mismatch
signer information mismatch [message #990066] Mon, 10 December 2012 12:39 Go to next message
I'm trying to run standalone setup as
import org.eclipse.xtext.generator.IGenerator;
import com.google.inject.Injector;
public class MainGen {
		Injector i = new FloStandaloneSetup().createInjectorAndDoEMFRegistration();
		IGenerator generator = i.getInstance(IGenerator.class);
I'm getting such exception
Caused by: java.lang.SecurityException: class "org.eclipse.xtext.parsetree.reconstr.impl.DefaultHiddenTokenHelper$$FastClassByGuice$$db42f815"'s signer information does not match signer information of other classes in the same package
at java.lang.ClassLoader.checkCerts(ClassLoader.java:943)
at java.lang.ClassLoader.preDefineClass(ClassLoader.java:657)
at java.lang.ClassLoader.defineClass(ClassLoader.java:785)
... 139 more
I think it it related to different versions but I don't understand what versions I should use. Can someone help with this. I attached list of libs I use.
index.php/fa/12656/0/
Thank you
  • Attachment: libs.jpg
    (Size: 376.66KB, Downloaded 493 times)
Re: signer information mismatch [message #990165 is a reply to message #990066] Tue, 11 December 2012 03:41 Go to previous messageGo to next message
Hi Igor,
which version of Xtext do you use? Please make sure that you use the
google inject bundle that ships with Eclipse.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 10.12.12 18:50, schrieb Igor Tkachev:
> Hi
> public static void main(String[] args) {
> ... 139 more
> Thank you
Re: signer information mismatch [message #990234 is a reply to message #990165] Tue, 11 December 2012 09:19 Go to previous message
The problem is solved by downloading and installing eclipse from scratch
Sebastian Zarnekow wrote on Tue, 11 December 2012 03:41
Hi Igor,
Sebastian
Go visit:
> Hi
> ... 139 more
> Thank you
Previous Topic:Rules regarding CrossReferences
Next Topic:XPath grammar implementation
Current Time: Fri Jul 25 23:46:47 EDT 2025
Powered by FUDForum. Page generated in 0.05158 seconds
