auto start generated product bundles [message #990229] |
Tue, 11 December 2012 08:59  |
Hello
I have an equinox server application which I build, using PDE product configuration.
Since it is a server application, I would like to start all bundles right away.
The launch configuration provides the option "Default Auto-Start:".
I did not find any similar configuration for the config.ini.
The main problem I encountered I have over 20 different product configurations.
Each customer of our software has his own feature, depending on the main software feature.
Each product configuration is based on the customer feature, actually a very simple clean way. But since I want to start all the bundles I have to add all the bundles with 'autoStart="true"' to the product configuration.
This is especially bad when I add or remove a bundle from the software. Having to update over 20 configurations.
Any solution? Did I miss a configuration property?
greets
Flavio
FUDForum. Page generated in 1.37626 seconds
