Home » Language IDEs » C / C++ IDE (CDT) » Mysql.h showing compile errors in eclipse
Mysql.h showing compile errors in eclipse [message #990211] Tue, 11 December 2012 07:18 Go to next message
Hai,
I'm trying to use mysql with Eclipse IDE.
I've installed mysql and included the header file in my program.
#include <my_global.h>
#include <mysql.h>
But when I compiled it, it is giving these errors.....
: undefined reference to `mysql_init'
: undefined reference to `mysql_real_connect'
: undefined reference to `mysql_error'
: undefined reference to `mysql_query'
: undefined reference to `mysql_use_result'
: undefined reference to `mysql_fetch_row'
: undefined reference to `mysql_free_result'
: undefined reference to `mysql_close'
collect2: ld returned 1 exit status
When I do Ctrl+Click on any of these functions, the editor correctly opens the header file.
Can I know where to add the libraries, include paths and linker flags of mysql in eclipse.
I'm using redhat enterprise linux 6.1 and Eclipse Juno
Thank you
Re: Mysql.h showing compile errors in eclipse [message #990411 is a reply to message #990211] Wed, 12 December 2012 05:49 Go to previous messageGo to next message
http://wiki.eclipse.org/CDT/User/FAQ#Adding_C.2FC.2B.2B_External_Libraries
Re: Mysql.h showing compile errors in eclipse [message #990550 is a reply to message #990411] Thu, 13 December 2012 00:19 Go to previous messageGo to next message
Hai,
I've given it like this.
1)Under properties->C/C++ Build->Settings->GCC Compiler->Includes
added var/lib/mysql, /usr/lib64/mysql and /usr/include/mysql
2)Under properties->C/C++ Build->Settings->GCC Compiler->Miscellaneous
-c -fmessage-length=0 $(mysql_config --cflags)
3)Under properties->C/C++ Build->Settings->GCC Linker->Libraries->Libraries(-I)
$(mysql_config --libs)
4)3)Under properties->C/C++ Build->Settings->GCC Linker->Libraries->Library search path(-L)
added /usr/include, var/lib/mysql, /usr/lib64/mysql and /usr/include/mysql
5)Under properties->C/C++ Build->Settings->GCC Linker->Miscellaneous
-pthread -lm -lrt
But, I'm still getting error:
gcc: argument to '-l' is missing
I think I'm missing something in the linker.
Thank you
Re: Mysql.h showing compile errors in eclipse [message #990616 is a reply to message #990550] Thu, 13 December 2012 08:01 Go to previous messageGo to next message
Usage of mysql_config in the command line options is not supported by Eclipse CDT. There is a plugin for pkg-config support.
http://code.google.com/p/pkg-config-support-for-eclipse-cdt/
Perhaps you can this one (or ask the author to help you).
Re: Mysql.h showing compile errors in eclipse [message #990751 is a reply to message #990616] Fri, 14 December 2012 00:39 Go to previous message
Hai,
Thanks for your reply.
I've added pkg-config, but I didn't see anything for mysql there.
using terminal, I can compile and link C file as
gcc -o exe $(mysql_config --cflags) main.c $(mysql_config --libs)
But, in eclipse I am not able to link it. I might be doing something wrong.
Previous Topic:"C/C++ Remote Application" debug launch configuration issues
Next Topic:CDT (C and C++ addon)
Current Time: Sun Jul 27 14:03:32 EDT 2025
Powered by FUDForum. Page generated in 0.03619 seconds
