Home » Modeling » EMF » [CDO/db4o store] Multi session/transaction problems
[CDO/db4o store] Multi session/transaction problems [message #990060] Mon, 10 December 2012 11:48 Go to next message
I'm trying to switch from Hibernate Store to db4o store.
I have 2 client applications that have their own Session/Transaction.
Transaction is never closed until the client isn't.
Assume Client1 = C1 & Client2 = C2.
C1 makes changes to its transaction
C1 commits
OK
C2 makes changes to its transaction
C2 commits
NOK !
It get this server side :
java.util.ConcurrentModificationException: Attempt by Transaction[4:1] to modify historical revision: OID2:0v13
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.isContainerLocked(TransactionCommitContext.java:802)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.lockObjects(TransactionCommitContext.java:735)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:434)
	at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:42)
	at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
	at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
Using debug in TransactionCommitContext.isContainerLocked(), I found that resource revision version is not incremented on C2 when C1 commits its changes.
Must I use PassiveUpdate mode ? I hope no cause it does not work in my app ...
Thanks !
UPDATE :
Same problem with DBStore
java.lang.IllegalStateException: Can only retrieve current version 14 for OID2 - version requested was CDORevisionDelta[CDOResource@OID2:0v13 --> [CDOFeatureDelta[contents, LIST, list=[CDOFeatureDelta[contents, ADD, value=oid1, index=105]]]]]
	at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readRevisionByVersion(DBStoreAccessor.java:283)
	at org.eclipse.emf.cdo.internal.server.Repository.loadRevisionByVersion(Repository.java:519)
	at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevisionByVersion(CDORevisionManagerImpl.java:236)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.isContainerLocked(TransactionCommitContext.java:798)
[Updated on: Mon, 10 December 2012 12:25] by Moderator
Re: [CDO/db4o store] Multi session/transaction problems [message #990142 is a reply to message #990060] Tue, 11 December 2012 01:42 Go to previous messageGo to next message
Hi Ben,
Please wait with that switch until we hear from Vik (the developer of the DB4O store) whether he plans to maintain it
properly. I won't! Of course you could decide to maintain it yourself or become a CDO committer ;-)
Cheers
/Eike
http://www.esc-net.de
Am 10.12.2012 17:48, schrieb ben ben:
> C1 commits
> OK
> C2 commits
> NOK !
> on C2 when C1 commit it's changes.
> Thanks !
Re: [CDO/db4o store] Multi session/transaction problems [message #990150 is a reply to message #990142] Tue, 11 December 2012 02:28 Go to previous messageGo to next message
Thanks for your reply Eike.
It would be a pleasure if I found enough time Wink
What about the same problem with DBStore (HSQLDB) ? I guess this store is properly maintained, no ?
Re: [CDO/db4o store] Multi session/transaction problems [message #990152 is a reply to message #990150] Tue, 11 December 2012 02:37 Go to previous messageGo to next message
Am 11.12.2012 08:28, schrieb ben ben:
> It would be a pleasure if I found enough time ;)
Let me know if you need help to run the tests for DB4O.
The DBStore is one of the best maintained stores. It's probably the one most used.
Cheers
/Eike
Re: [CDO/db4o store] Multi session/transaction problems [message #990154 is a reply to message #990152] Tue, 11 December 2012 02:53 Go to previous messageGo to next message
I get the same problem with DBStore. I tried :
- Derby
- H2
- HSQLDB
- MySQL
I'm probably missing something ...
[Updated on: Tue, 11 December 2012 02:57] by Moderator
Re: [CDO/db4o store] Multi session/transaction problems [message #990157 is a reply to message #990154] Tue, 11 December 2012 03:12 Go to previous messageGo to next message
Am 11.12.2012 08:53, schrieb ben ben:
> - Derby
> - H2
> - HSQLDB
Okay, I'll try to reproduce it in a test. Please cc yourself to https://bugs.eclipse.org/bugs/show_bug.cgi?id=396181
Cheers
/Eike
Re: [CDO/db4o store] Multi session/transaction problems [message #990159 is a reply to message #990157] Tue, 11 December 2012 03:21 Go to previous messageGo to next message
Done !
Eike Stepper wrote on Tue, 11 December 2012 03:12
> - Derby
> - H2
> - HSQLDB
Cheers
/Eike
Re: [CDO/db4o store] Multi session/transaction problems [message #990174 is a reply to message #990159] Tue, 11 December 2012 04:44 Go to previous messageGo to next message
I'm beginning to understand ....
First of all, I made a mistake, the problem also occurs with Hibernate Store (sorry for db4o & DBStore).
To summarize, CDOObjects commited by C1 & C2 are directly contained into CDOResource.
On commit, CDOResource is tagged as "modified object", so it's commited and its revision is incremented.
I'm going to change my model to avoid this problem, but can you confirm that having to commit CDOResource when a new contained object is added into is a normal behavior ?
Re: [CDO/db4o store] Multi session/transaction problems [message #990175 is a reply to message #990174] Tue, 11 December 2012 04:48 Go to previous messageGo to next message
Am 11.12.2012 10:44, schrieb ben ben:
Correct.
Yes. Every possible commit change set contains at least 1 changed object, even if you only made additions or deletions
(they will always change the container object).
Cheers
/Eike
Re: [CDO/db4o store] Multi session/transaction problems [message #990177 is a reply to message #990175] Tue, 11 December 2012 05:01 Go to previous message
OK. Thanks for all your help.
Previous Topic:[CDO/Hibernate] detaching objects with references
Next Topic:Implement a third-party interface in EMF
Current Time: Sat Jul 26 20:05:49 EDT 2025
Powered by FUDForum. Page generated in 0.11550 seconds
