Home » Modeling » OCL » Accessing parent
Accessing parent [message #990083] Mon, 10 December 2012 14:31 Go to next message
Hi everyone,
previously (OCL Examples and Editors 3.1.x in Indigo) it was possible to access the container/parent of an element (or maybe it is considered non-navigable opposite) like this (assuming that X contains Y and the context is Y): self.X
In the current version this doesn't work anymore. What is the alternative (or best way) to achieve this?
Matthias
Re: Accessing parent [message #990087 is a reply to message #990083] Mon, 10 December 2012 15:03 Go to previous messageGo to next message
self.X should work. Do you mean Juno SR1 by the current version?
self.oclContainer().oclAsType(X) may also work.
Ed Willink
On 10/12/2012 19:31, Matthias Schoettle wrote:
> Hi everyone,
> Matthias
Re: Accessing parent [message #990089 is a reply to message #990087] Mon, 10 December 2012 15:22 Go to previous messageGo to next message
Hi Ed,
yes, I mean Juno SR1.
It seems that the error message that I get doesn't affect saving the ecore file (other errors don't allow to save) and the constraint (in this case) still gets evaluated. So it still works, despite the error message being shown in the editor:
The feature 'element' of 'org.eclipse.ocl.examples.xtext.base.baseCST.impl.PathElementCSImpl@1c7c571e{platform:/resource/MyProject/model/My.ecore#//@ownedNestedPackage.0/@ownedType.2/@ownedConstraint.2/@specification/@ownedExpression/@ownedExpression.1/@pathName/@path.0}' contains a dangling reference 'org.eclipse.ocl.examples.pivot.internal.impl.PropertyImpl@368c9326{#//}'
- Matthias
[Updated on: Mon, 10 December 2012 15:33] by Moderator
Re: Accessing parent [message #990208 is a reply to message #990089] Tue, 11 December 2012 07:09 Go to previous messageGo to next message
The JUnit test for unnavigable containment navigation seems to be
unchanged since March 2011 so I'm unclear why you observe a change.
I've added a more intensive testing of alternative containment spellings
and they all works fine in my working branch.
"dangling reference" can come from other causes; most likely the failure
in the synthesized type reification prior to save.
Can you post a simplified zipped project demonstrating the problem? In
particular what are the types of self, C and their relationship?
Ed Willink
On 10/12/2012 20:22, Matthias Schoettle wrote:
> Hi Ed,
> self.X doesn't work for me anymore, unfortunately. This is the error
> message: The feature 'element' of
> - Matthias
Re: Accessing parent [message #1005327 is a reply to message #990208] Thu, 24 January 2013 16:54 Go to previous messageGo to next message
sorry for the late response.
I unfortunately cannot reproduce this error with a new model (i.e., a simplified version). It randomly appears in my file. With a new model it didn't happen.
I found two other problems though that worked before. You can find an example attached.
Matthias
  • Attachment: ocltest.zip
    (Size: 1.67KB, Downloaded 257 times)
Re: Accessing parent [message #1005382 is a reply to message #1005327] Fri, 25 January 2013 03:12 Go to previous message
And the problems that you see are??
This newsgroup/forum is searchable so that similar problems and
solutions can be shared. If you don't identify your problems you deny
others the opportunity to share. This is totally contrary to the ethos
of Open Source and Eclipse; and also a waste of my time.
I see only one problem with the attached; you have stored OCLinEcore
concrete syntax as a *.ecore file, so opening the file with any EMF tool
bombs. Use *.oclinecore for OCLinEcore concrete syntax.
Ed Willink
On 24/01/2013 21:54, Matthias Schoettle wrote:
> Regards,
> Matthias
Previous Topic:CompleteOCL parser problem
Next Topic:CompleteOCL parser problem
Current Time: Fri Jul 18 23:16:07 EDT 2025
Powered by FUDForum. Page generated in 0.04692 seconds
