Home » Eclipse Projects » Eclipse Scout » Corrupted file using IRemoteFileService ...
Corrupted file using IRemoteFileService ... [message #989193] Wed, 05 December 2012 02:20 Go to next message
Hi!
I followed the example listed here : http://wiki.eclipse.org/Scout/HowTo/3.7/Use_RemoteFileService.
I have this configuration:
### Server RemoteFileService root path
org.eclipse.scout.rt.server.services.common.file.RemoteFileService#rootPath=/home/me/remotefiles/
In my source code, this portion works fine ...
String source = "pdfFile.pdf";
final RemoteFile result = SERVICES.getService(IRemoteFileService.class).getRemoteFile(new RemoteFile(source, 0L));
MyForm#this#AbstractBrowserField#setValue(result);
Except that the result file seems to be corrupted!
So, the used AbstractBrowserField renders for example, for this pdf file, the same number of pages as the source file on the scout server but the texts disappears ... even if the result file is flushed on another directory (i.e. not in the AbstractBrowserField).
What could be the reason?
Thank you!
Re: Corrupted file using IRemoteFileService ... [message #989234 is a reply to message #989193] Wed, 05 December 2012 05:19 Go to previous messageGo to next message
You need to identify where something get wrong:
- When putting a PDF File into the RemoteFile Object (could be an encoding problem).
- When transfering the Remote file from the Server to the Client
- When the AbstractBrowserField read the PDF file
- When the AbstractBrowserField renders the PDF.
You could start your investigation with:
* An other file than a PDF file (eg. Text file without any special char).
* Loading the PDF directly on the client and passing it to the AbstractBrowserField.
Do not hesitate to post your findings here...
Re: Corrupted file using IRemoteFileService ... [message #989282 is a reply to message #989234] Wed, 05 December 2012 09:07 Go to previous messageGo to next message
I think it's a matter of charset:
when trying to get a simple text file, everything works fine even with special characters!
typing the command "file -i sample.txt" returns utf-8 encoding; the default charset.
So I tried "file -i pdffile.pdf" and I got binary as encoding charset.
the new problem is now that I don't know how to supply 'binary' as charset (final RemoteFile result = SERVICES.getService(IRemoteFileService.class).getRemoteFile(new RemoteFile(source, 0L, "binary")); always returns an incorrect file)
Re: Corrupted file using IRemoteFileService ... [message #990072 is a reply to message #989282] Mon, 10 December 2012 13:02 Go to previous messageGo to next message
I think that you try to do something was never done with Eclipse Scout.
I am not sure that the RemoteFile and IRemoteFileService is suitable to transfert PDF. That is something we could try to support.
Do you have a minimal application (I imagine a just need a single from application with a Browser Field) and an example PDF (Or does it append with every PDF File) ?
Re: Corrupted file using IRemoteFileService ... [message #990086 is a reply to message #990072] Mon, 10 December 2012 14:44 Go to previous messageGo to next message
the same problem happens on evrey kind of file (mp3, jpg, ....) except text files for wich the transfert is successful.
you're right saying that the this is new to Scout, in my opinion, the RemoteFileService only works right now for text files. (DecompressedReader/Writer should be enhanced to handle binary files I think)
[Updated on: Mon, 10 December 2012 14:48] by Moderator
Re: Corrupted file using IRemoteFileService ... [message #990207 is a reply to message #990086] Tue, 11 December 2012 07:02 Go to previous messageGo to next message
For your information, I am using remote file service (Scout Indigo SR2) to transfer mp3 files from server to client and then play them. That works fine.
Regards Bertin
      protected void execAction() throws ProcessingException {
        String filename = getGeluidFilenameColumn().getSelectedValue();
        RemoteFile file = SERVICES.getService(IRemoteFileService.class).getRemoteFile(new RemoteFile("sounds", filename, 0l));
        if (file.exists()) {
          try {
            file.extractData();
            InputStream is = new ByteArrayInputStream(file.extractData());
            Sound.playMP3(is);
          catch (IOException e) {
            e.printStackTrace();
        else {
          MessageBox mb = new MessageBox("File not found", filename, "OK");
          mb.setIconId(Icons.StatusError);
          mb.setAutoCloseMillis(2000);
          mb.startMessageBox();
Re: Corrupted file using IRemoteFileService ... [message #990353 is a reply to message #990207] Wed, 12 December 2012 01:41 Go to previous message
hello,
thank you for your answer, but your proposed solution requires to transform the resulting as your destination component (the MP3 players) uses an InputStream.
This doesn't macth well with my situation where I use an AbstractBrowser, which needs a (result) RemoteFile as parameter.
Previous Topic:Deleting Rows in TableField not calling store
Next Topic:Reusing the same formData member on more than one field
Current Time: Sun Jul 27 22:29:04 EDT 2025
Powered by FUDForum. Page generated in 0.25568 seconds
