Home » Modeling » OCL » serialization of CompleteOCL document to XMI format
serialization of CompleteOCL document to XMI format [message #986595] Wed, 21 November 2012 01:55 Go to next message
Hi all,
I would like to know if it is possible to serialize an CompleteOCL document to xmi format? If yes, how exactly please?
I have an completeOCL document like this
import 'MyEcore.ecore'
package test
context TestClass
I would like to generate the xmi file which refers to the ecore elements (classes, packages, attributes, etc.)
Please help me
Best regards
[Updated on: Wed, 21 November 2012 01:56] by Moderator
Re: serialization of CompleteOCL document to XMI format [message #986630 is a reply to message #986595] Wed, 21 November 2012 04:17 Go to previous messageGo to next message
The CST can be serialized by saving the CST Resource to an XMI file.
(This is currently only available programmatically.)
The AST can be serialized by saving the AST (Pivot) Resource to an XMI
file, but since Complete OCL complements an existing meta-model, this
also serialises the complemented meta-model.
(This might be available interactively by using Load Complete OCL
Resource to merge into the Sampkle Excore Editior, then doing SaveAs...)
Ed Willink
On 21/11/2012 06:55, Fy Za wrote:
> Hi all, I would like to know if it is possible to serialize an
> package test
> context TestClass
> Please help me
> Best regards
Re: serialization of CompleteOCL document to XMI format [message #989914 is a reply to message #986630] Sun, 09 December 2012 20:31 Go to previous messageGo to next message
Hi Ed,
How to serialize the AST of a CompleteOCL Document programmatically?
There is some code in tests packages?
Can you please help me!
Fy Za
Re: serialization of CompleteOCL document to XMI format [message #989930 is a reply to message #989914] Mon, 10 December 2012 01:54 Go to previous messageGo to next message
I didn't understand your last question so I gave you two answers.
You haven't indicated which you have tried or what you wanted.
Basically you just use the standard EMF Resource.save() and when looking
for examples you can always use Eclipse search tools such as File or
Java search.
Ed Willink
On 10/12/2012 01:31, Fy Za wrote:
> Hi Ed,
> Best regards,
> Fy Za
Re: serialization of CompleteOCL document to XMI format [message #990000 is a reply to message #989930] Mon, 10 December 2012 07:18 Go to previous messageGo to next message
Hi Ed,
I am sorry whether it is not very clear.
I try to serialize a CompleteOCLDocument in order to generate the AST
programmatically.
I dont find codes in sources of OCL (in the Git).
Best regards
Fy Za
Re: serialization of CompleteOCL document to XMI format [message #990033 is a reply to message #990000] Mon, 10 December 2012 10:45 Go to previous messageGo to next message
To be more precise,
I have an OCLDocument test.ocl with applied to Simple.ecore
I define this class:
package Parser;
import java.io.IOException;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.ocl.examples.xtext.completeocl.CompleteOCLStandaloneSetup;
public class Parser {
	public static void main(String[] args) throws IOException {
		CompleteOCLStandaloneSetup.doSetup();
		ResourceSet resourceSet = new ResourceSetImpl();
		Resource resource = resourceSet.createResource(URI.createURI(args[0]));
		resource.load(null);
		Resource resourceAsXmi = resourceSet.createResource(URI.createURI(args[0]+".generated.xmi"));
		resourceAsXmi.getContents().addAll(resource.getContents());
		resourceAsXmi.save(null);
It generates a file which named test.generated.xmi
I generate another xmi file with saveAs xmi command of test.ocl named test.saveas.xmi
test.generated.xmi doesn't resolve paths (like in this example test.ocl#xtextLink_::0.10.0.6.1.0::2::/1)
  <ownedImport>
    <pathName>
      <path xsi:type="baseCST:PathElementWithURICS">
        <element xsi:type="pivot:Annotation" href="/CompleteOCLParser/Case/test.ocl#xtextLink_::0.10.0.6.1.0::2::/1"/>
      </path>
    </pathName>
  </ownedImport>
However the test.saveas.xmi resolve them (Simple.ecore#/)
  <ownedImport>
    <namespace xsi:type="pivot:Model" href="pivot:/platform/resource/CompleteOCLParser/Case/Simple.ecore#/"/>
  </ownedImport>
So, What I should modify or add in the parser class to get the results of test.saveas.xmi programmaticly ?
Fy Za
[Updated on: Mon, 10 December 2012 10:46] by Moderator
Re: serialization of CompleteOCL document to XMI format [message #990056 is a reply to message #990033] Mon, 10 December 2012 11:44 Go to previous messageGo to next message
Use EcoreUtil.resolveAll.
You haven't motivated your use of a saved Complete OCL and I cannot
envisage why it would be helpful, so I suspect you have many more
problems in stire.
Ed Willink
On 10/12/2012 15:45, Fy Za wrote:
> To be more precise,
> package Parser;
> import
> Resource resource =
> test.saveas.xmi
> The difference test.generated.xmi doesn't resolve paths (like in this
> <ownedImport>
> <pathName>
> </path>
> </pathName>
> </ownedImport>
> <ownedImport>
> </ownedImport>
> Best regards,
> Fy Za
Re: serialization of CompleteOCL document to XMI format [message #990069 is a reply to message #990056] Mon, 10 December 2012 12:45 Go to previous messageGo to next message
when I use EcoreUtil.resolveAll(resource);
package Parser;
import org.eclipse.emf.ecore.util.EcoreUtil;
		Resource resourceAsXmi = resourceSet.createResource(URI.createURI(args[0]+".xmi"));
I have errors:
Exception in thread "main" org.eclipse.ocl.examples.pivot.utilities.IllegalLibraryException: No OCL Standard Library content available
	at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.getRequiredLibraryType(PivotStandardLibrary.java:278)
	at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.resolveRequiredSimpleType(PivotStandardLibrary.java:377)
	at org.eclipse.ocl.examples.pivot.manager.PivotStandardLibrary.getOclInvalidType(PivotStandardLibrary.java:207)
	at org.eclipse.ocl.examples.xtext.base.baseCST.impl.PathElementCSImpl.getElement(PathElementCSImpl.java:354)
	at org.eclipse.ocl.examples.xtext.base.baseCST.impl.PathNameCSImpl.getElement(PathNameCSImpl.java:391)
	at org.eclipse.ocl.examples.xtext.completeocl.completeOCLCST.impl.ClassifierContextDeclCSImpl.getClassifier(ClassifierContextDeclCSImpl.java:201)
	at org.eclipse.ocl.examples.xtext.completeocl.completeOCLCST.impl.ClassifierContextDeclCSImpl.eIsSet(ClassifierContextDeclCSImpl.java:168)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObjectImpl.java:1237)
	at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.hasNext(EContentsEList.java:401)
	at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImpl.next(EContentsEList.java:559)
	at org.eclipse.emf.ecore.util.EcoreUtil.resolveCrossReferences(EcoreUtil.java:302)
	at org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(EcoreUtil.java:296)
	at org.eclipse.emf.ecore.util.EcoreUtil.resolveAll(EcoreUtil.java:281)
	at Parser.Parser.main(Parser.java:32)
Re: serialization of CompleteOCL document to XMI format [message #990079 is a reply to message #990069] Mon, 10 December 2012 13:49 Go to previous messageGo to next message
If you Google for "No OCL Standard Library content available " you find
that the top hit is http://www.eclipse.org/forums/index.php/m/931858/
Ed Willink
Re: serialization of CompleteOCL document to XMI format [message #990128 is a reply to message #990079] Mon, 10 December 2012 19:56 Go to previous messageGo to next message
Hi Ed,
Thank you!
It is resolved!!
I add two lines
package Parser;
import org.eclipse.ocl.examples.pivot.model.OCLstdlib;
import org.eclipse.ocl.examples.xtext.oclinecore.OCLinEcoreStandaloneSetup;
		OCLinEcoreStandaloneSetup.doSetup();
		OCLstdlib.install();
However, two differences between test.saveas.xmi and test.generated.xmi still persists:
1-
In the "save as xmi" file named test.saveas.xmi, I have a the top
<?xml version="1.0" encoding="ASCII"?>
<completeOCLCST:CompleteOCLDocumentCS xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:baseCST="http://www.eclipse.org/ocl/3.1.0/BaseCST" xmlns:completeOCLCST="http://www.eclipse.org/ocl/3.1.0/CompleteOCLCST" xmlns:essentialOCLCST="http://www.eclipse.org/ocl/3.1.0/EssentialOCLCST" xmlns:pivot="http://www.eclipse.org/ocl/3.1.0/Pivot">
  <ownedImport>
  </ownedImport>
However, The parser generated file named test.generated.xmi, I have for the same part
  <ownedImport>
    <pathName>
        <element xsi:type="pivot:Root" href="pivot:/file/Users/faiez/Modeling/workspace_juno_02122012/CompleteOCLParser/Case/Simple.ecore#/"/>
      </path>
    </pathName>
  </ownedImport>
2-
In the "save as xmi" file named test.saveas.xmi, I have for example (/null/Users/fyza/Modeling/workspace_ocl/)
<name xsi:type="essentialOCLCST:NameExpCS">
                  <pathName>
                    <path>
                      <element xsi:type="pivot:Variable" href="pivot:/null/Users/fyza/Modeling/workspace_ocl/CompleteOCLParser/Case/test.ocl#//@nestedPackage.0/@ownedType.0/@ownedOperation.0/@ownedRule.0/@specification/@bodyExpression/@iterator.0"/>
                    </path>
                  </pathName>
                </name>
However, The parser generated file named test.generated.xmi, I have for the same part(/platform/resource/):
                  <pathName>
                    <path>
                      <element xsi:type="pivot:Variable" href="pivot:/platform/resource/CompleteOCLParser/Case/test.ocl#//@nestedPackage.0/@ownedType.1/@ownedOperation.0/@ownedRule.0/@specification/@bodyExpression/@iterator.0"/>
                    </path>
                  </pathName>
                </name>
Do you know what I should modify or add in the parser in order to eliminate these differences.
Fy Za
[Updated on: Tue, 11 December 2012 02:38] by Moderator
Re: serialization of CompleteOCL document to XMI format [message #990194 is a reply to message #990128] Tue, 11 December 2012 06:05 Go to previous messageGo to next message
indicates a file that was opened as
platform:/resource/CompleteOCLParser/Case/Simple.ecore
pivot:/file/Users/faiez/Modeling/workspace_juno_02122012/CompleteOCLParser/Case/SimplePDL.ecore
file:/Users/faiez/Modeling/workspace_juno_02122012/CompleteOCLParser/Case/SimplePDL.ecore
if you want EMF to work consistently, you should avoid file: paths
wherever possible. Use URI.createPlatformResourceURI and
StandaloneProjectMap.
Ed Willink
On 11/12/2012 00:57, Fy Za wrote:
> Hi Ed,
> Thank you!
> I add two lines
> package Parser;
> import
> import
> Resource resource =
> However, two differences still persists:
> 1-
> <ownedImport>
> </ownedImport>
> <ownedImport>
> <pathName>
> href="pivot:/file/Users/faiez/Modeling/workspace_juno_02122012/CompleteOCLParser/Case/SimplePDL.ecore#/"/>
> </path>
> </pathName>
> </ownedImport>
> 2- In the "save as xmi" file named test.saveas.xmi, I have for example
> <pathName>
> <path>
> </path>
> </pathName>
> </name>
> <pathName>
> <path>
> </path>
> </pathName>
> </name>
> Best regards,
> Fy Za
Re: serialization of CompleteOCL document to XMI format [message #990235 is a reply to message #990194] Tue, 11 December 2012 09:22 Go to previous messageGo to next message
I add this line:
URI uri = URI.createPlatformPluginURI("org.eclipse.emf.ecore", true);
However, for StandaloneProjectMap, I don't know what I should define, what method, what parameters!!!! etc.
can you explain to me more, Please!
because I don't find nothing in Google Sad
package Parser;
		System.out.println(uri);
Re: serialization of CompleteOCL document to XMI format [message #990273 is a reply to message #990235] Tue, 11 December 2012 11:50 Go to previous messageGo to next message
Users of Eclipse are expected to be able to show some initiative....
Have you looked at the javadoc?
Have you searched for references?
ed Willink
On 11/12/2012 14:22, Fy Za wrote:
> Hi, I add this line: URI uri =
> because I don't find nothing in Google :(
> package Parser;
> import
> import
> true);
> Resource resource =
Re: serialization of CompleteOCL document to XMI format [message #990357 is a reply to message #990273] Wed, 12 December 2012 02:08 Go to previous messageGo to next message
Hi Ed,
Yes, I look in javadoc.
There is no concrete code. There is just some discussions!
I edit the code, but no modifications in the generated xmi file.
Can you PLEASE edit this code!
at least, tell me, what I should do exactly with StandaloneProjectMap
and How relate it with the initial code?
regards!
Fy
package Parser;
import org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl;
import org.eclipse.ocl.examples.domain.utilities.ProjectMap;
import org.eclipse.ocl.examples.domain.utilities.StandaloneProjectMap;
import org.eclipse.ocl.examples.domain.utilities.StandaloneProjectMap.IPackageDescriptor;
import org.eclipse.ocl.examples.domain.utilities.StandaloneProjectMap.IProjectDescriptor;
import simplepdl.SimplepdlPackage;
//import org.eclipse.ocl.examples.domain.utilities.StandaloneProjectMap;
//import org.eclipse.ocl.examples.domain.utilities.StandaloneProjectMap.ProjectDescriptor;
		String project = SimplepdlPackage.class.getPackage().getName();
		String modelPath = project + "/model/SimplePDL.ecore";
		ProjectMap.getResourceFactoryRegistry(null).getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
		URI nsURI = URI.createURI(SimplepdlPackage.eINSTANCE.getNsURI());
		URI pluginURI = URI.createPlatformPluginURI(modelPath, true);
		URI resourceURI = URI.createPlatformResourceURI(modelPath, true);
		ProjectMap projectMap = new ProjectMap();
		projectMap.initializeResourceSet(resourceSet);
		IProjectDescriptor projectDescriptor = projectMap.getProjectDescriptor(project);
		IPackageDescriptor packageDescriptor = projectDescriptor.getPackageDescriptor(URI.createURI(SimplepdlPackage.eINSTANCE.getNsURI()));
		packageDescriptor.setUseModel(true, resourceSet.getPackageRegistry());
		Resource registeredResource = resourceSet.getResource(nsURI, true);
[Updated on: Wed, 12 December 2012 02:20] by Moderator
Re: serialization of CompleteOCL document to XMI format [message #990376 is a reply to message #990357] Wed, 12 December 2012 03:34 Go to previous messageGo to next message
> Yes, I look in javadoc. There is no concrete code. There is just some
> discussions!
No.
I'm sorry but if you are unable to read the Javadoc, look at the code or
search for examples, you should reconsider how you spend you time.
Ed Willink
Re: serialization of CompleteOCL document to XMI format [message #990448 is a reply to message #990376] Wed, 12 December 2012 09:33 Go to previous message
Hi Ed,
I read documentation,
I found the ProjectMapTest in org.eclipse.ocl.examples.test.ecore
I found also testProjectMap_Pivot_Local() method which can help me to resolve this problem.
I tryed to adopt it in my context, however, the problem still persists.
package Parser;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.plugin.EcorePlugin;
import simple.SimplePackage;
		String project = SimplePackage.class.getPackage().getName();
		System.out.println(project);
		IPackageDescriptor packageDescriptor = projectDescriptor.getPackageDescriptor(URI.createURI(SimplePackage.eINSTANCE.getNsURI()));
Previous Topic:OCL in Xtext editor: Quick fixes for constraints
Next Topic:Using static variables in OCL constraints
Current Time: Sat Jul 26 02:51:30 EDT 2025
Powered by FUDForum. Page generated in 0.08752 seconds
