Eclipse view rendering issue [message #989994] |
Mon, 10 December 2012 06:21  |
Eclipse view rendering issue: In my custom created view if I switch to another view and comeback, my view is faded out (the the view has two tabs which will be visible but the composite inside the tab all turns white). Looks like view rendering issue. Need some suggestions badly! Below is the stack trace:
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. com.sap.ndb.studio.modeling.tools.actionSet
at org.eclipse.core.commands.contexts.Context.getParentId(Context.java:201)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.getLevel(ContextSet.java:48)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.compare(ContextSet.java:38)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.compare(ContextSet.java:1)
at java.util.Arrays.mergeSort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at java.util.Collections.sort(Unknown Source)
at org.eclipse.e4.ui.bindings.internal.ContextSet.<init>(ContextSet.java:76)
at org.eclipse.e4.ui.bindings.internal.BindingTableManager.createContextSet(BindingTableManager.java:90)
at org.eclipse.e4.ui.bindings.internal.BindingServiceImpl.setContextIds(BindingServiceImpl.java:236)
at sun.reflect.GeneratedMethodAccessor8.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:88)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:107)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:318)
at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:332)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activate(EclipseContext.java:630)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activateBranch(EclipseContext.java:635)
at org.eclipse.e4.ui.internal.workbench.PartActivationHistory.activate(PartActivationHistory.java:52)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:561)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:532)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:105)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:61)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1447)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java:2836)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:2417)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:5152)
at org.eclipse.swt.widgets.Tree.WM_SETFOCUS(Tree.java:7064)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4598)
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5958)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:1098)
at org.eclipse.swt.widgets.Control.setFocus(Control.java:3303)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:1040)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:1038)
at org.eclipse.ui.part.PageBookView.setFocus(PageBookView.java:881)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.delegateSetFocus(CompatibilityPart.java:178)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:235)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:206)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:106)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$2.setFocus(ContributedPartRenderer.java:101)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer$9.mouseUp(StackRenderer.java:941)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:220)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
FUDForum. Page generated in 0.03363 seconds
