Home » Modeling » TMF (Xtext) » [Syntactic predicates] Choosing alternative path 2
[Syntactic predicates] Choosing alternative path 2 [message #989871] Sat, 08 December 2012 16:49 Go to next message
I have a very small grammar (simplified part of Xbase) with a common problem:
warning(200): ../org.xtext.example.mydsl/src-gen/org/xtext/example/mydsl/parser/antlr/internal/InternalMyDsl.g:186:2: Decision can match input such as
"'<' RULE_ID '>' {RULE_ID, '<'}" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
I know, how to choose alternative 1 hiding the warning, but how to choose alternative 2?
Here are the details:
I want to parse ID, comparation of ID, and IDs with generics '<String>' (just like method calls in Xtend '<String>myMethod(null)')
The grammar without syntactic predicates:
Model: (expressions += Comparation)*;
Comparation returns Expression:
	NumberExpression ({Comparation.left=current} op=('<' | '>') right=NumberExpression)*;
NumberExpression returns Expression:
	({NumberExpression} value=NumberLiteral)
NumberLiteral:
		('<' type=ID '>')?
		value=ID
This grammar accepts multiple expressions, like
print
<String>print
a > b
<String>getA < <String>getB
Changing the Comparation rule to the
	NumberExpression ( =>({Comparation.left=current} op=('<' | '>')) right=NumberExpression)*;
I can choose alternative 1 and get ride of the warning. Now, the input like
print
<String>getA
get parsed like
print < String > getA
(Xtend has the same issue, by the way)
Now I would like to choose the second alternative, so that the input above would get parsed, like a call to "print" and then a call to "<String>getA".
Within the ANTLR it's possible adding following gated semantic predicate:
('<' RULE_INT '>' RULE_INT)=>
after the '*' in the Comparation rule. So mixing Xtext and ANTLR it would be:
	NumberExpression {Comparation.left=current} op=('<' | '>') right=NumberExpression)*  ANTLR>>>   ('<' RULE_INT '>' RULE_INT)=>    <<<ANTLR;
Now is it possible to do this in the Xtext?
Is it possible to add such gated semantic predicate at the generation time right to the ANTLR grammar, if no better ways are available?
Thank you and sorry for the long post!
Boris Brodski
Re: [Syntactic predicates] Choosing alternative path 2 [message #989927 is a reply to message #989871] Mon, 10 December 2012 01:27 Go to previous messageGo to next message
Did you try something like:
NumberLiteral:
=>(('<' type=ID '>')? value=ID)
=> is "if you can parse then next, then use that path"
Don't know if that helps in this case. I could not quite follow your
example when RULE_INT started appearing - what is RULE_INT?
- henrik
On 2012-08-12 22:49, Boris Brodski wrote:
> Hello,
> problem:
> warning(200):
> NumberLiteral:
> ('<' type=ID '>')?
> value=ID
> print
> <String>print
> a > b
> print
> <String>getA
> get parsed like
> "<String>getA".
> would be:
> <<<ANTLR;
> Best regards,
> Boris Brodski
Re: [Syntactic predicates] Choosing alternative path 2 [message #989965 is a reply to message #989927] Mon, 10 December 2012 04:54 Go to previous messageGo to next message
Hello Henrik,
yes, I tried this one. And also this one:
NumberLiteral:
( =>('<' type=ID '>' value=ID) )
| value=ID
But nothing works even, if I take MyGrammar.g, remove all actions, put this predicate and call ANTLR manually. A ANTLR tutorial states, that such predicates should be placed at the most left on the alternative path. The NumberLiteral non-terminal is already to late. The decision will be made at the asterisk in '( ... )*' in the Comparation.
Boris
Re: [Syntactic predicates] Choosing alternative path 2 [message #989966 is a reply to message #989965] Mon, 10 December 2012 04:58 Go to previous messageGo to next message
Hello Henrik,
to address your last question: RULE_INT is the ANTLR name for the INT in the Xtext.
I put it into the ANTLR>>> ... <<<ANTLR to indicate, that the '...' is native ANTLR syntax. This '...' should be
inserted directly into the MyGrammar.g after is was generated from MyGrammar.xtext.
Boris
Re: [Syntactic predicates] Choosing alternative path 2 [message #990028 is a reply to message #989966] Mon, 10 December 2012 09:45 Go to previous message
> the Xtext.
> MyGrammar.xtext.
I had similar issues and I solved those with an external lexer i.e. (in
your case) deliver other tokens than < and > when facing < int >.
- henrik
Previous Topic:Extended highlighting breaks embedded editor highlighting
Next Topic:Issue generating a DSL grammar
Current Time: Wed Jul 23 07:45:24 EDT 2025
Powered by FUDForum. Page generated in 0.05448 seconds
