Home » Eclipse Projects » Equinox » Http Service
Http Service [message #98965] Sun, 30 September 2007 15:28 Go to next message
Originally posted by: abo.splitshade.de
I try hard to get behind some Implementationdetails in equinox.
One important Question I don?t understand is, what do this lines do?
context = bundleContext;
Object[] proxyServlets = serviceRegistrations.keySet().toArray();
for (int i = 0; i < proxyServlets.length; ++i) {
ServiceRegistration registration = registerHttpService((ProxyServlet)
proxyServlets[i]);
serviceRegistrations.put(proxyServlets[i], registration);
context.registerService(HttpService.class.getName(), factory,
serviceProperties);
This is what happens in the 'org.eclipse.equinox.http.servlet.internal'
package in the Activator class.
What seems to happen here is, that there are several http-Services
registered?
Why would one do that? I thought, only one http-service is needed?
Any Help appreciated
Martin
Re: Http Service [message #98995 is a reply to message #98965] Sun, 30 September 2007 21:10 Go to previous messageGo to next message
Hi Martin,
You're right in that code is for handling multiple instances of the Http
Service.
This is not typical but can be useful in some circumstances.Most uses
involve extra ports to perhaps provide a public facing web port for one Http
Service instance as well as an internal management port for another. In
other cases multiple Http Services are used simply to provide some isolation
of the URI space between applications.
-Simon
"Martin Dilger" <abo@splitshade.de> wrote in message
news:fdotdf$56b$1@build.eclipse.org...
> proxyServlets[i]);
> serviceProperties);
> registered?
> Martin
Re: Http Service [message #99010 is a reply to message #98995] Mon, 01 October 2007 02:02 Go to previous message
Ah ok, that makes sense, thank you very much, it?s a little confusing in
the first view..
Greetings
Martin
Simon Kaegi schrieb:
> Hi Martin,
> Service.
> -Simon
>> Hi,
>> proxyServlets[i]);
>> serviceProperties);
>> registered?
>> Martin
Previous Topic:class not found even after package exported
Next Topic:Equinox Extension loading buggy?
Current Time: Mon Oct 20 02:23:47 EDT 2025
Powered by FUDForum. Page generated in 0.03470 seconds
