Home » Modeling » Epsilon » Native java code Tools example
Native java code Tools example [message #989552] Thu, 06 December 2012 12:25 Go to next message
Dear all,
I want to instantiate an EData Type (org.eclipse.draw2d.geometry.Rectangle) that is defined in my ecore model. This cannot be done directly, so I believe I'm required to use an AbstractTool with corresponding extension point?
Therefore, I'm trying to invoke the example given here: http://www.eclipse.org/epsilon/doc/articles/call-java-from-epsilon
However, the SampleTool is not found for some reason.
I couldn't find the mentioned .launch script, so here is the stacktrace from my plugin:
Type 'org.eclipse.epsilon.examples.tools.SampleTool' not found (/DEV/myplugin.xml.to.cspm/epsilon/transform.etl@13:28)
	at org.eclipse.epsilon.eol.types.EolNativeType.<init>(EolNativeType.java:37)
	at org.eclipse.epsilon.eol.execute.TypeExecutor.execute(TypeExecutor.java:75)
	at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(ExecutorFactory.java:226)
	at org.eclipse.epsilon.eol.execute.NewExecutor.execute(NewExecutor.java:26)
	at org.eclipse.epsilon.eol.execute.AssignExecutor.execute(AssignExecutor.java:48)
The used ETL script (line 13 onwards):
var sampleTool = new Native("org.eclipse.epsilon.examples.tools.SampleTool");
sampleTool.name = "George";
sampleTool.sayHello().println();
My eclipse version is Indigo SR2 + Epsilon 1.0.0.
Robert
Re: Native java code Tools example [message #989610 is a reply to message #989552] Thu, 06 December 2012 17:57 Go to previous messageGo to next message
Hi Robert,
This article provides an example that demonstrates how to create a new Java tool; SampleTool is not a real tool included in the Epsilon distribution. As such, to use it you'll need to create it first by going through the steps of the article, launch a new Eclipse instance and use it from there.
Dimitris
Re: Native java code Tools example [message #989679 is a reply to message #989610] Fri, 07 December 2012 04:50 Go to previous messageGo to next message
Hi Dimitris,
Let me clearify this. I downloaded the example, imported the plugin project in Eclipse & ran a new Eclipse instance (from the first Eclipse instance). The plugin is 'found', since I checked this in the installation details (Help -> About Eclipse).
However, the SampleTool is not found in the script.
Robert
[Updated on: Fri, 07 December 2012 04:50] by Moderator
Re: Native java code Tools example [message #989717 is a reply to message #989679] Fri, 07 December 2012 07:23 Go to previous messageGo to next message
Hi Robert,
This seems to be working fine for me. Could you perhaps check if you can instantiate any of the other tools (see Window->Show view...->Tools for a complete list of available tools)?
Dimitris
Re: Native java code Tools example [message #989724 is a reply to message #989717] Fri, 07 December 2012 07:51 Go to previous messageGo to next message
Hmm, this is strange. The SampleTool and others (like JavaTool, MathTool, etc) are shown in this view.
However, the example ETL script (still) doesn't work for me.
Re: Native java code Tools example [message #989729 is a reply to message #989724] Fri, 07 December 2012 08:03 Go to previous messageGo to next message
Are you launching the .eol script through a launch configuration or through Java code?
Dimitris
Re: Native java code Tools example [message #989734 is a reply to message #989729] Fri, 07 December 2012 08:16 Go to previous messageGo to next message
I'm running it from Java code, to be specific with an EtlModule.
Note, for the rest, I can succesfully transform models using this ETL/java code.
Re: Native java code Tools example [message #989739 is a reply to message #989734] Fri, 07 December 2012 08:23 Go to previous messageGo to next message
Have you perhaps added the following line to your Java setup as advised in the article?
context.getNativeTypeDelegates().add(new ExtensionPointToolNativeTypeDelegate());
Dimitris
Re: Native java code Tools example [message #990031 is a reply to message #989739] Mon, 10 December 2012 10:15 Go to previous message
Thank you very much. This was indeed missing and all works fine now.
Robert
Previous Topic:[EGL] Create a folder
Next Topic:Epsilon flock
Current Time: Wed Jul 23 05:45:10 EDT 2025
Powered by FUDForum. Page generated in 0.31857 seconds
