Home » Eclipse Projects » NatTable » Weird issue with FilterRow and Scrollbars
icon5.gif  Weird issue with FilterRow and Scrollbars [message #989517] Thu, 06 December 2012 10:09 Go to next message
Hello all,
I'm currently working on a NatTable powered application that makes use of filters. The code is pretty much adapter for Dirk's example posted way back in 2011 in the Eclipse magazine. It all works well however I've noticed the following weird behavior on Windows 7 *only*:
There's a table with filters configured. You can set and delete filters all day long. If no rows are available the filters continue to work. However, if rows become available and the vertical scrollbar gets drawn then it's a different matter.
Activating filters once more makign sure that no rows become available will make the vertical scrollbar disappear, which will push the NatTable's content a bit further into the right. And here comes the problem, you can't click on the "delete filter" icon anymore. You can't even click on the header to select the column. It's as if the space that the scrollbar used to occupy is reserved, or as if the NatTable's dimensions were not updated when the scrollbar went away.
Has anyone experienced something similar? Is this a bug perhaps?
Environment
Eclipse
Version: Juno Service Release 1
Build id: 20120920-0800
org.eclipse.nebula.widgets.nattable.core_0.9.0.201209230003
Windows 7 Ultimate SP1
Re: Weird issue with FilterRow and Scrollbars [message #989525 is a reply to message #989517] Thu, 06 December 2012 10:53 Go to previous messageGo to next message
Hi Andres,
no I haven't faced this issue yet. The current implementation is enabling/disabling the scrollbars when it calculates them to do so.
Some questions to follow your issue:
1. You are saying that you have created some kind of adapter to my examples. I don't need details, but what's the customization?
2. You are saying that the NatTable grows to the right (if I understand that correctly). Well this is the NatTable feature for percentage sizing which is quite new and yet undocumented AFAIK. Are you using this feature or is this the customization you did with your adapter?
3. Usually the NatTable content should grow if you don't use percentage sizing. So it could also be an issue with the size of the table in terms of matching the size of the container. Therefore it would be helpful to see how you integrate the NatTable into your Composite.
Greez,
Dirk
Re: Weird issue with FilterRow and Scrollbars [message #989530 is a reply to message #989525] Thu, 06 December 2012 11:21 Go to previous messageGo to next message
Hi Dirk,
1. The customization is related to a LazyLoadingDataLayer we custom built for this project, which sadly makes no use of GlazedLists at all.
2. Yes indeed, we're making use of the percentage sizing feature. Here's a snippet on how we set it up
lazyLoadingDataLayer.setColumnPercentageSizing(true);
for (int i = 0; i < columns.size(); i++) {
    lazyLoadingDataLayer.setColumnWidthPercentageByPosition(i, columns.get(i).getWidthPercentage());
We also setup the NatTable using the default style + SWT.BORDER. I wonder, is it possible to instruct the table to always draw the Vertical scrollbar? I must confess the issue has me stumped as it cannot be reproduced in either Linux nor Mac (insert witty retort on how Windows sucks big time here Wink
3. The NatTable is embedded using MigLayout
//main layout
final LC lc = new LC().fill().wrapAfter(2).insets("0");
final AC cc = new AC().size("310", 0).fill(0, 1).gap("0:0").grow(1, 1);
final AC rc = new AC().fill().grow(1).align("center");
final MigLayout basicLayout = new MigLayout(lc, cc, rc);
// table
manager.getNatTable().setLayoutData("w n:400, h 45:200");
wouldn't the column constraint mean that the table grows in the horizontal dimension? However if setColumnPercentageSizing(false) is set then all columns are drawn with the same size and the table's area is not filled.
Thanks!
Re: Weird issue with FilterRow and Scrollbars [message #989655 is a reply to message #989530] Fri, 07 December 2012 03:17 Go to previous messageGo to next message
Hi Andres,
but you are using GlazedLists in the NatTable, aren't you? Otherwise, which FilterRow are you using? Currently it is only usable with GlazedLists (changing this is still on my ToDo list).
Currently not as the ViewportLayer takes care if the scrollbars should be shown or not dependent on the content. Maybe this needs to be adjusted, but until now there was no such requirement. Smile
I never used MigLayer before. For me the SWT FormLayout was always good enough. Maybe I need to have a look at this in the future. Smile
I don't understand which column constraint you mean. Compared to a SWT table, the NatTable doesn't grow to fill the whole space. To be more precise, the NatTable as the Canvas on which the table is painted of course grows dependent to the layout. But what is painted to the Canvas (the cells itself) doesn't know about the layout. Of course the ViewportLayer knows about the size of the visible part to determine whether to show scrollbars or not, but that information isn't transfered to the cell rendering itself. This needs to be configured independent of the layout manager you are using.
Hope the informations help in some kind of way.
I will try to modify my example to reproduce your issue.
Greez,
Dirk
Re: Weird issue with FilterRow and Scrollbars [message #989668 is a reply to message #989655] Fri, 07 December 2012 04:13 Go to previous messageGo to next message
Hi Andres,
I modified my FilterableNatTableExample from the article in the Eclipse magazine 3.2012 (not the one in 2011 Wink ) to use the percentage sizing feature. And there I could not see the issue you are describing.
I then modified it for using a container composite for the NatTable and use the SWT GridLayout manager. Still this issue doesn't exist.
So I'll assume that this issue is related to the MigLayout rather than the NatTable. To prove this I'll suggest, you switch to another layout manager temporarily and check if this strange behaviour still exists. An easy one could be the GridLayout (which is not the same as the GridLayout in Swing, compared to Swing it is more like the GridBagLayout).
//create a layout with one column
container.setLayout(new GridLayout());
//set layout data to your NatTable instance that uses the whole available space by growing on resizing
GridDataFactory.fillDefaults().grab(true, true).applyTo(natTable);
I tried to use the MigLayout in my example, but as I'm not familiar with it, it would take to much time.
Hope this helps,
Dirk
Re: Weird issue with FilterRow and Scrollbars [message #989685 is a reply to message #989655] Fri, 07 December 2012 05:09 Go to previous messageGo to next message
We circumvented the usage of GlazedLists alltogether. Here's for example how our FilterGridLayer setups the columnHeader
protected ILayer createColumnHeaderLayer(BodyLayerStack bodyLayer,
        Map<String, String> titleToAttributeNameMap,
        IConfigRegistry configRegistry) {
    ILayer columnHeaderLayer = super.createColumnHeaderLayer(bodyLayer,
            titleToAttributeNameMap, configRegistry);
    FilterRowHeaderComposite<I> filterRowHeaderLayer = new FilterRowHeaderComposite<I>(
            new IFilterStrategy<I>() {
                public void applyFilter(
                        Map<Integer, Object> filterObjectByIndex) {
                    if (filterCallback == null) return;
                    Map<String, Object> filterValuesPerColumn = new LinkedHashMap<String, Object>();
                    for (Map.Entry<Integer, Object> entry : filterObjectByIndex
                            .entrySet()) {
                        filterValuesPerColumn.put(
                                getColumnProperty(entry.getKey()),
                                entry.getValue());
                    // trigger callback only if filter key/values changed from last time
                       if (!areEqual(previousFilterValuesPerColumn, filterValuesPerColumn)) {
                        filterCallback.filter(filterValuesPerColumn);
                        previousFilterValuesPerColumn.clear();
                        previousFilterValuesPerColumn.putAll(filterValuesPerColumn);
            }, columnHeaderLayer, columnHeaderDataLayer.getDataProvider(),
            configRegistry);
    return filterRowHeaderLayer;
This layer detects when filters change, collects all relevant information and triggers a filterCallback. It also remember the last filter combination in order to avoid triggering the callback with the same search arguments.
It would be great if we could programmatically instruct ViewportLayer to always draw scrollbars.
MigLayout and GlazedLists => best 3rd party libraries to build UIs, You can ask Sascha Wink
Lastly, what I meant about the constraints is that grow is set on the table, this instructs the composite to let the table grow in both vertical and horizontal space as it becomes available. This does not affect the inner draw space of the table at all (that is, it won't affect column sizes directly unless of course they are setup in a way that their width changes if the table gets resized).
So, our observations indicate that the table itself is not resized when the vertical scrollbar appears then disappears, i.e, the canvas' size is [400, 400] and remains that size. But it looks like inner dimensions in the table itself are not updated when the vertical scrollbar is hidden, as the effect is that the space where the vertical scrollbar used to be is not selectable/clickable.
Hope this information helps.
Re: Weird issue with FilterRow and Scrollbars [message #989691 is a reply to message #989685] Fri, 07 December 2012 05:30 Go to previous messageGo to next message
Hi Andres,
thanks for the information about your approaches to use the filter row without GlazedLists. This will help me on moving it from GlazedLists extension to core.
I heard about MigLayout before, but never used in a SWT project. Mainly because I'm familiar and satisfied with the SWT layout managers. Smile Also because I haven't found an OSGi packaged version of MigLayout.
Nevertheless, as I told before, I can't reproduce this behaviour with e.g. the SWT GridLayout. So either my example is not complex enough to bring this up, or MigLayout is the bad guy. Could you please try to reproduce your issue with a SWT default layout manager?
Re: Weird issue with FilterRow and Scrollbars [message #1405013 is a reply to message #989691] Wed, 06 August 2014 07:24 Go to previous message
Hello all,
i also bumped into a similar issue, although i'm using a standard layout manager:
- at start, vertical scroll bar must be visible
- open a filter editor
- set a filter condition that causes all rows to disappear
- this also causes the vertical bar to disappear (the filter editor is still open)
- change the filter condition again, and here comes the surprise..
- the filter values are set to the column on the left of the original column
Since i couldn't get to the source of the problem, my first idea was also to change the scroll bar to always remain visible.
Unfortunately this is difficult ass hell with the current API, so i post here my very-very ugly workaround:
// build nattable as you would normally
natTable = new NatTable(this, gridLayer, false);
// here comes the ugly workaround to haven an always-visible vertical scroll bar
final ScrollBarScroller scroller = new ScrollBarScroller(natTable.getVerticalBar()) {
	public void setVisible(boolean b) {
		// this does the trick (as it doesn't do anything)
final VerticalScrollBarHandler vBarListener = new VerticalScrollBarHandler(viewportLayer, scroller);
final Field tableField = ReflectionUtils
		.getDeclaredFieldRecursively(VerticalScrollBarHandler.class, "table");
ReflectionUtils.setFieldValue(tableField, vBarListener, natTable);
final Field vBarListenerField = ReflectionUtils
		.getDeclaredFieldRecursively(ViewportLayer.class, "vBarListener");
ReflectionUtils.setFieldValue(vBarListenerField, viewportLayer, vBarListener);
natTable.setConfigRegistry(configRegistry);
// etc...
natTable.configure();
ReflectionUtils is a utility class of mine that simplifies reflection related tasks, i assume the method names are verbose enough the see what's happening.
[Updated on: Wed, 06 August 2014 07:36] by Moderator
Previous Topic:Using FilterList for tree in NatTable
Next Topic:NatTable is not refreshed correctly
Current Time: Sun Nov 09 09:57:05 EST 2025
Powered by FUDForum. Page generated in 0.04090 seconds
