[CDO] HibernateStore UnsupportedOperationException [message #989518] |
Thu, 06 December 2012 10:20  |
I am using CDO 4.1 with the HibernateStore Configuration with EMF 2.8.0, EclipseLink 2.4.0, Teneo 2.0.0 and Hibernate 4.1.1.
When I create new objects in my CDO Client, add them to a resource (in my empty database) and commit them, everything works fine. I can also change values of these attributes and commit these changes without problems.
However creating new objects and adding them to a resource that already consists of objects (of the same type) leads to a UnsupportedOperationException on the CDO HibernateStore:
[ERROR] UnsupportedOperationException
java.lang.UnsupportedOperationException
at org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORevisionLazyInitializer.getPersistentClass(CDORevisionLazyInitializer.java:40)
at org.hibernate.proxy.HibernateProxyHelper.getClassWithoutInitializingProxy(HibernateProxyHelper.java:44)
at org.hibernate.type.AnyType.toLoggableString(AnyType.java:201)
at org.hibernate.type.CollectionType.renderLoggableString(CollectionType.java:193)
at org.hibernate.type.CollectionType.toLoggableString(CollectionType.java:184)
at org.hibernate.internal.util.EntityPrinter.toString(EntityPrinter.java:79)
at org.hibernate.internal.util.EntityPrinter.toString(EntityPrinter.java:121)
at org.hibernate.event.internal.AbstractFlushingEventListener.logFlushResults(AbstractFlushingEventListener.java:131)
at org.hibernate.event.internal.AbstractFlushingEventListener.flushEverythingToExecutions(AbstractFlushingEventListener.java:107)
at org.hibernate.event.internal.DefaultFlushEventListener.onFlush(DefaultFlushEventListener.java:51)
at org.hibernate.internal.SessionImpl.flush(SessionImpl.java:1127)
at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.doWrite(HibernateStoreAccessor.java:700)
at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:149)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:487)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:43)
at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:262)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:96)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:86)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:92)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:65)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:680)
On CDO Client side I get the following exception:
Error: org.eclipse.emf.cdo.util.CommitException: Rollback in HibernateStore: java.lang.UnsupportedOperationException
at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:85)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1134)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1154)
Does anyone have an idea why I get this exception and how can I avoid it?
Thanks for help
Stephan
[Updated on: Thu, 06 December 2012 10:28] by Moderator
Re: [CDO] HibernateStore UnsupportedOperationException [message #989566 is a reply to message #989524] |
Thu, 06 December 2012 13:50   |
Hi Stephan,
It makes sense to upgrade to latest CDO 4.2 build (at least for the hibernate store, see the update site link in my
previous post).
You don't need to upgrade EMF. You need the latest build of Teneo though. Hibernate 4.1.1 is fine, not sure why you need
EclipseLink though (as you already have hibernate there).
gr. Martin
On 12/06/2012 04:50 PM, Stephan Krusche wrote:
> Hi Martin,
> I am using the following version:
> - CDO 4.1
> - EMF 2.8.0
> - EclipseLink 2.4.0 - Teneo 2.0.0
> - Hibernate 4.1.1.
> When I try out CDO 4.2, do I need to upgrade EMF, EclipseLink, Teneo or Hibernate?
> Thanks and best regards
> Stephan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.04470 seconds
