Home » Modeling » TMF (Xtext) » Errors and warnings not shown in my editor
Errors and warnings not shown in my editor [message #989486] Thu, 06 December 2012 08:02 Go to next message
I'm trying to understand why errors and warnings are not shown in the editor for my language... Shocked
According to the manual, I would expect error messages generated automatically (basing on grammar definition, for example) by the underlying parser technology to be automatically displayed on the screen. Instead, on the left side of the editor does not appear any icon for errors or warnings.
I also implemented a custom validator (subclass of AbstractDeclarativeValidator) and tested it to be sure it throws correctly a warning. But when I start the editor, nothing appears when it should appear.
Finally, I noticed that if I open Window -> Preferences and then I select My language -> Compiler, there isn't an Errors/Warnings sub-item of the menu, as for Java.
Could you help me, please? Crying or Very Sad
Marco
[Updated on: Thu, 06 December 2012 08:11] by Moderator
Re: Errors and warnings not shown in my editor [message #989490 is a reply to message #989486] Thu, 06 December 2012 08:22 Go to previous messageGo to next message
Hi this should work out Of The box. Did you try a plain new greeting
example. BTW there should be already a mydsljavavalidator class you
can simply edit
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Errors and warnings not shown in my editor [message #989498 is a reply to message #989490] Thu, 06 December 2012 08:58 Go to previous messageGo to next message
Christian Dietrich wrote on Thu, 06 December 2012 08:22
What do you mean? :/
BTW there should be already a mydsljavavalidator class you can simply edit
As I said, I implemented a check method in that class and tested it with a JUnit test case, but when I launch the editor, it has no effect (I don't see my warning Shocked ).
Re: Errors and warnings not shown in my editor [message #989500 is a reply to message #989498] Thu, 06 December 2012 09:03 Go to previous messageGo to next message
Can you post your code
Re: Errors and warnings not shown in my editor [message #989713 is a reply to message #989500] Fri, 07 December 2012 06:37 Go to previous message
I solved by recreating my project from zero.
Now, it's ok. Smile
Thanks anyway, bye! Smile
Marco
Previous Topic:CharSequence inside while
Next Topic:Embedded editor is missing some functionality
Current Time: Wed Jul 23 04:07:33 EDT 2025
Powered by FUDForum. Page generated in 0.11766 seconds
