Home » Language IDEs » C / C++ IDE (CDT) » Eclipse cannot find already included libraries ? (Desparate for help)
Eclipse cannot find already included libraries ? (Desparate for help) [message #988620] Fri, 30 November 2012 12:40 Go to next message
Hi everyone. I have been experiencing this - perhaps tiny - problem for days, and I cannot seem to figure out what is wrong.
So when i try to compile in eclise i get this...
/bin/ld: cannot find -l/usr/lib64/libGL.so
/bin/ld: cannot find -l/usr/lib64/libGL.so.1
/bin/ld: cannot find -l/usr/lib64/libGL.so.1.2
I have included those paths in the "paths and symbols" section on properties.
The error appeared when I included those paths. Before that, there used to be underlinings in my code (undefined references). After the libs were included the code became recognizable but i get the error above.
Please I need help with this as it's holding me back from getting on with my work.
Cheers!
*If I am not posting this at the right forum please do let me know as Im not sure.
Thanks in advance!
Re: Eclipse cannot find already included libraries ? (Desparate for help) [message #988646 is a reply to message #988620] Fri, 30 November 2012 15:39 Go to previous messageGo to next message
Did you explicitly specify the libraries as /usr/lib64/libGL.so etc? This isn't how you specify libraries to the linker. You need to give it the path to look in (/usr/lib64) and specify the library name without the lib prefix and .so suffix. In your case you should only specify GL as the library to include.
Re: Eclipse cannot find already included libraries ? (Desparate for help) [message #988862 is a reply to message #988620] Mon, 03 December 2012 08:43 Go to previous messageGo to next message
That's the wrong place. See http://wiki.eclipse.org/CDT/User/FAQ#Adding_C.2FC.2B.2B_External_Libraries
Re: Eclipse cannot find already included libraries ? (Desparate for help) [message #989281 is a reply to message #988620] Wed, 05 December 2012 09:02 Go to previous messageGo to next message
Ok that didn't help either.
The guide is refering to an older version, however i did what I could:
Project properties > C/C++ Build > Settings > Tool Settings > Cross G++ Linker > Libraries > Add (-l) > /usr/lib64
Now Im getting this error:
13:40:56 **** Incremental Build of configuration Debug for project hello_malaka ****
make all
Building target: hello_malaka
Invoking: Cross G++ Linker
g++  -o "hello_malaka"  ./hello.o   -l/usr/lib64
collect2: error: ld returned 1 exit status
make: *** [hello_malaka] Error 1
index.php/fa/12603/0/
Re: Eclipse cannot find already included libraries ? (Desparate for help) [message #989285 is a reply to message #989281] Wed, 05 December 2012 09:28 Go to previous messageGo to next message
I am not too up on C++ development (I am primarily a Java developer) however I believe that you have to add /usr/lib64 to the search path (the lower box) and then add "GL" (minus the quotes) to the libraries box (the upper box). The command generated should be something like:
g++ -o "hello_malaka" ./hello.o -L/usr/lib64 -lGL
[Updated on: Thu, 06 December 2012 10:41] by Moderator
Re: Eclipse cannot find already included libraries ? (Desparate for help) [message #989290 is a reply to message #988620] Wed, 05 December 2012 09:47 Go to previous messageGo to next message
I have done that :
index.php/fa/12605/0/
Error now:
make all
g++ -L/usr/lib64 -o "hello_malaka"  ./hello.o   -lglut -lglu -lGL
/bin/ld: cannot find -lglu
Still getting error that I don't understand. It can't find glu but CAN find everything else. glu is there as well...
[Updated on: Wed, 05 December 2012 09:48] by Moderator
Re: Eclipse cannot find already included libraries ? (Desparate for help) [message #989295 is a reply to message #989290] Wed, 05 December 2012 09:53 Go to previous messageGo to next message
Are you sure that the library is glu. Should it be capitalized as GLU?
Re: Eclipse cannot find already included libraries ? (Desparate for help) [message #989298 is a reply to message #989290] Wed, 05 December 2012 09:58 Go to previous messageGo to next message
Ok I think i fixed it!
I had to include GLEW, GL and glut in -l (top window).
So I located them and added the path to the bottom window! Now It compiles!!!!
Thanks for your help everyone !
Re: Eclipse cannot find already included libraries ? (Desparate for help) [message #989302 is a reply to message #988620] Wed, 05 December 2012 10:01 Go to previous message
Quick parenthesese. Id like to mark this as solved. Can someone tell me how to do that real quick ? cheers
Previous Topic:Using CDT with Eclipse Indigo(3.7) on Solaris 10
Next Topic:Cross compiler for DOS?
Current Time: Sat Jul 26 11:30:48 EDT 2025
Powered by FUDForum. Page generated in 0.05058 seconds
