Home » Eclipse Projects » GEF » Separate view model and business model (How to split model business data model and graphical data model?)
Separate view model and business model [message #987805] Wed, 28 November 2012 04:02 Go to next message
I am doing a project with GEF and EMF.
How to split the model into business data model and graphical data model?
Are there any exist example how to do it?
Re: Separate view model and business model [message #988944 is a reply to message #987805] Mon, 03 December 2012 17:38 Go to previous messageGo to next message
Don't have an existing example for you, due to the fact that I'm a newbie to this entire world of GEF\EMF\Eclipse infras...
But I can tell you it's very much possible though not the easiest thing to do, I'll share my process hopefully will help you.
I started out with having a semi-working GEF editor and an EMF model that was specific for the GEF view. I changed the model to the meet the Business/Real Life/Spoken model.
At that point of course nothing worked; so after a few failed attempts I went on and built another abstraction layer of my own, that meets the following:
1. Built and translated from/to the model language (and it has the knowledge into how)
2. The objects together build the "GEF-model"
3. Main repository of all working objects in a session (not a must but makes life easier)
following this most, but not all, of the GEF code was left unchanged, kept working, and thought to be working with the direct model.
hope this helps.
good luck,
Eyal
Re: Separate view model and business model [message #989244 is a reply to message #988944] Wed, 05 December 2012 05:46 Go to previous message
You can try out JWT. It allws you to create a seperate views for your models
http://www.eclipse.org/jwt/
It has its own API's
[Updated on: Wed, 05 December 2012 05:47] by Moderator
Previous Topic:Text Superscript/Subscript
Next Topic:Connection Layer on the back
Current Time: Fri Jul 25 23:06:58 EDT 2025
Powered by FUDForum. Page generated in 0.04331 seconds
