Home » Language IDEs » Java Development Tools (JDT) » Compilation of the eclipse run-time kernel or vanilla eclipse
Compilation of the eclipse run-time kernel or vanilla eclipse [message #989154] Tue, 04 December 2012 16:54 Go to next message
I'm trying to build eclipse from scratch. I could download eclipse e4 from CVS, which has 426 projects. After the automatic build, I got tens of broken project build. I tried to fix some of them, but most of them are still broken including swt and jface.
Googling about eclipse architecture, I found that Wikipedia points out that
`With the exception of a small run-time kernel, everything in Eclipse is a plug-in.`
What projects in CVS are the run-time kernel? How many projects do I need to build `successfully` to get vanilla eclipse that is not a plugin but core eclipse? I mean what is the project that after the build I can execute `eclipse.exe` even though it has no plugin?
Any hints for building them would also be great.
Re: Compilation of the eclipse run-time kernel or vanilla eclipse [message #989165 is a reply to message #989154] Tue, 04 December 2012 18:12 Go to previous messageGo to next message
Sungmin Cho wrote on Tue, 04 December 2012 22:54
CVS is outdated. Eclipse projects now live in git at http://git.eclipse.org/c/
You mean when building inside the IDE? Or are you building from the command line?
SWT sure is among the trickier projects, since it needs fragments with native code for each platfrom.
For the bare minimum have a look at http://www.eclipse.org/equinox/documents/quickstart-framework.php
Note, that eclipse.exe is just a launcher, which is not necessarily needed.
Also note, that the Equinox bundle is not "Eclipse" its just an OSGi runtime, but it seems you are looking for that, exactly.
HTH,
Stephan
Re: Compilation of the eclipse run-time kernel or vanilla eclipse [message #989167 is a reply to message #989165] Tue, 04 December 2012 18:23 Go to previous messageGo to next message
ah, and for launching the Equinox console you may want to read https://bugs.eclipse.org/bugs/show_bug.cgi?id=371101 ;-/
Re: Compilation of the eclipse run-time kernel or vanilla eclipse [message #1053644 is a reply to message #989154] Tue, 07 May 2013 02:38 Go to previous message
You might try downloading from the Eclipse Platform project. I had the same question/objective and after installing Eclipse Platform I get a very generic workbench with very few menu items / buttons.
You could probably trim more plug-ins out of the Platform folders, but some stuff will probably stop working. It would be a interesting experiment. . .
Previous Topic:Wanted: Eclipse Plugin Developer
Next Topic:Eclipse code completion for file names?
Current Time: Sat Jul 26 11:36:07 EDT 2025
Powered by FUDForum. Page generated in 0.07230 seconds
