Home » Modeling » EMF » [CDO] ClassCastException when removing one entry from the model
[CDO] ClassCastException when removing one entry from the model [message #989023] Tue, 04 December 2012 05:48 Go to next message
I have a simple test, where I get the resource and try to remove the last entry from the contents list:
CDOResource resource = tx.getOrCreateResource(RESOURCE_NAME);
EList<EObject> contents = resource.getContents();
int size = contents.size();
contents.remove(size-1);
tx.commit();
The list contains 200.000 entries.
If I run the test just after starting the CDO server, then I get this exception when committing:
java.lang.ClassCastException: org.eclipse.emf.cdo.internal.server.TransactionCommitContext$DeltaLockWrapper$ForID cannot be cast to org.eclipse.emf.cdo.spi.common.id.AbstractCDOID
	at org.eclipse.emf.cdo.common.id.CDOIDUtil.write(CDOIDUtil.java:501)
	at org.eclipse.emf.cdo.spi.common.protocol.CDODataOutputImpl.writeCDOID(CDODataOutputImpl.java:343)
	at org.eclipse.emf.cdo.spi.common.protocol.CDODataOutputImpl.writeCDOLockState(CDODataOutputImpl.java:294)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.UnlockObjectsIndication.responding(UnlockObjectsIndication.java:83)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndication.responding(CDOServerIndication.java:134)
	at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
	at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:298)
	at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerWriteIndication.execute(CDOServerWriteIndication.java:39)
java.lang.IllegalMonitorStateException
	at org.eclipse.net4j.util.concurrent.RWOLockManager.unlock2(RWOLockManager.java:187)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.unlockObjects(TransactionCommitContext.java:1026)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.rollback(TransactionCommitContext.java:1155)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.handleException(TransactionCommitContext.java:583)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:532)
	at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:46)
	at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
	at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
	at org.eclipse.emf.cdo.internal.server.Repository.commitUnsynced(Repository.java:917)
	at org.eclipse.emf.cdo.internal.server.Repository.commit(Repository.java:910)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:295)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:97)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
	at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:86)
If I rerun the test without restarting the CDO server, then the test succeeds.
Am I doing something wrong?
Or is there other more efficient way to remove entries?
Might it be due to the huge amount of entries in the list? I was expecting that the number of entries in this case was not relevant, because it should remove directly from the index, without iterating over all the list, right?
However, is not in the remove that is takes too long to execute, but during the commit.
Silvestre
[Updated on: Tue, 04 December 2012 05:49] by Moderator
Re: [CDO] ClassCastException when removing one entry from the model [message #989113 is a reply to message #989023] Tue, 04 December 2012 11:33 Go to previous messageGo to next message
Am 04.12.2012 11:48, schrieb Silvestre Martins:
> tx.commit();
I think that's a bug that noone has uncovered before. Should be easy to fix by letting DeltaLockWrapper extend
AbstractCDOID. Please submit a bugzilla.
> at
> at
> at
> at
> at
I can currently not judge whether this is a follow-up problem of the one above. Let's address that one first.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] ClassCastException when removing one entry from the model [message #989119 is a reply to message #989113] Tue, 04 December 2012 11:55 Go to previous messageGo to next message
Bugzilla created:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=395736
Re: [CDO] ClassCastException when removing one entry from the model [message #989127 is a reply to message #989119] Tue, 04 December 2012 12:45 Go to previous message
Am 04.12.2012 17:55, schrieb Silvestre Martins:
> Bugzilla created:
And resloved: commit bccf2d8a11ec27fcab9768fa5a921411dcc33970
Please try again...
Cheers
/Eike
Previous Topic:[CDO] OCL Query to sql
Next Topic:[CDO] launch error with offline example
Current Time: Wed Jul 23 21:39:57 EDT 2025
Powered by FUDForum. Page generated in 0.04855 seconds
