Home » Eclipse Projects » EGit / JGit » How to gc an amazon-s3 remote with jgit?(amazon s3 git garbage collection)
How to gc an amazon-s3 remote with jgit? [message #880684] Sat, 02 June 2012 13:42 Go to next message
I've been using jgit for a while, configured to use amazon s3 as a backing store, by specifying a remote of amazon-s3 in .git/config. Does anyone know how to do a git-gc on the git state in s3? It's accumulating a ton of files and could use some cleaning.
Josh
Re: How to gc an amazon-s3 remote with jgit? [message #880927 is a reply to message #880684] Sun, 03 June 2012 07:46 Go to previous messageGo to next message
can't you just mount the s3 bucket into your filesystem and then run a git-gc with native git. JGit has a garbage collector only in an open, not yet accepted change (https://git.eclipse.org/r/#/c/4705/) - so I suggest you use native git.
Re: How to gc an amazon-s3 remote with jgit? [message #893624 is a reply to message #880927] Wed, 04 July 2012 21:24 Go to previous messageGo to next message
Hi Christian,
I tried s3fs and it looks like it can't read directories created with jgit.
There is a thread on the s3fs issues page (I can't provide link since I'm new to Eclipse) of people talking about s3fs being limited in ability to see dirs created by other packages. It's id=73. Any empirically, I can't see anything inside a bucket mounted via s3fs.
Any other ideas? Seems like there's gotta be a way.
Josh
Re: How to gc an amazon-s3 remote with jgit? [message #988920 is a reply to message #880927] Mon, 03 December 2012 12:33 Go to previous messageGo to next message
The code to GC over s3 has been committed and merged into jgit as of version 2.1.0
Is there a way to trigger this code from the jgit CLI?
Re: How to gc an amazon-s3 remote with jgit? [message #989067 is a reply to message #988920] Tue, 04 December 2012 08:59 Go to previous messageGo to next message
I think that we (and also native git) don't have a gc algorithm which works on remote repositories. It is always like that that the GC algorithms want to work on a local repository. But we do have in jgit multiple kinds of local repositories regarding how data is persisted. We do have traditional Filesystem based repositories (implmented in FileRepository) which store the repo date in a .git folder. There is also a kind of repo storing the data in a DFS (implemented in DfsRepository.java). The way how repos store their data influences heavily what kind of garbage can exist and therefore we have different GC implementations for these two repo types (implemented in GC.java and DfsGarbageCollector.java). But: we don't have a repository type which stores data in S3. I fear that doing a gc for S3 is quite a lot of effort. One has to know how data is stored in S3, which garbage can exist and so on. Can't you do a poor man's gc: clone the S3 based repo to the local Filesystem, run a local gc, delete the content on S3 and push the local repo to S3?
Re: How to gc an amazon-s3 remote with jgit? [message #989071 is a reply to message #989067] Tue, 04 December 2012 09:04 Go to previous messageGo to next message
Another thought: have you tried https://github.com/tongwang/s3fs-c?
Re: How to gc an amazon-s3 remote with jgit? [message #989101 is a reply to message #989067] Tue, 04 December 2012 10:38 Go to previous messageGo to next message
Hi Christian,
Jgit has some support for s3. The jgit page on github (can't link because I'm too new to this site) says the s3 pack files don't support delta-ification, but functionally it works (and i use it). Looking at the source code, there's a suggestive bit:
public class TransportAmazonS3 extends HttpTransport implements WalkTransport
Given that it's implemented at what sounds like a low-level transport layer, the question becomes, will your GC code work with repositories stored via HttpTransports?
Re s3fs: I think the s3fs does not work with the way jgit uses s3. I think it's because of the way that the jgit s3 code names directories - it's not compatible with how s3fs does it (i vaguely remember seeing something about nulls and separators online somewhere)
Re: How to gc an amazon-s3 remote with jgit? [message #989110 is a reply to message #989101] Tue, 04 December 2012 11:25 Go to previous messageGo to next message
I know about TransportAmazonS3. This means that transport related jgit commands (fetch, push, clone, ...) can work with remote repositories located in S3. Means we can clone a repo stored on S3 into a filesystem based local repo. Or we can push from a filesystem based local repo into a remote repo stored on S3. With TransportAmazonS3 we learn how to talk to remote repos stored in S3. But those repos are still remote repositories. And GarbageCollector have nothing to do with transports. They want to work on local repos. There is no support in jgit I know of that a local repository stores it's data in S3.
Re s3fs: I fully agree. s3fs seems not to work with the way jgit uses s3. But s3fs-c differs from s3fs exactly in this topic. And maybe s3fs-c is compatible with the way how jgit stores the path information.
Whats about clone-to-local -> garbage_collect_local -> delete_and_recreate_empty_repo_on_S3 -> push_local_to_S3
Re: How to gc an amazon-s3 remote with jgit? [message #999714 is a reply to message #989110] Sat, 12 January 2013 19:07 Go to previous messageGo to next message
I've been fiddling around with s3fs-c and sort of got it to work with jgit/s3. A few things I've found:
- I needed to specify "sharedRepository = all" in the config file on s3.
- The -ouse_cache doesn't work at all for me. When I specify an existing, empty directory, it is not populated, and any attempt to access files on s3 produces a 'bad file descriptor' error, though listing directory contents works fine.
- I have not yet gotten git-gc to work on s3fs-c. It always dies part-way through with different kinds of data corruption errors. I've observed that s3fs-c doesn't like reading files after they've been written. E.g., if I modify the git config and then 'cat ./config', I get truncated contents, like it's using the wrong file size when reading.
Re: How to gc an amazon-s3 remote with jgit? [message #1721969 is a reply to message #880684] Mon, 01 February 2016 20:07 Go to previous messageGo to next message
An update to this ancient thread. I recently was able to gc a jgit remote repo on s3 using s3fs-fuse (https://github.com/s3fs-fuse/s3fs-fuse).
I did something like:
Download s3fs
git checkout tags/v1.79
autogen/configure/make
$ mkdir /home/me/s3-mount
$ s3fs [amazon-bucket-name] /home/me/s3-mount -o passwd_file=[path to s3 credential file] -o umask=0000 -o url=https://s3.amazonaws.com
$ GIT_DIR=/home/me/s3-mount/[git subdir] git gc
The tricky part was figuring out to put in the -o umask=0000 flag. Without it, I got permission denied errors trying to access s3.
All this was done without root.
Re: How to gc an amazon-s3 remote with jgit? [message #1722468 is a reply to message #1721969] Fri, 05 February 2016 02:48 Go to previous message
nice that you found a way to gc a remote jgit s3 repository
Previous Topic:JGit - Can't get remote's error message from failed push
Next Topic:adding git commit message template
Current Time: Wed Jul 23 08:14:30 EDT 2025
Powered by FUDForum. Page generated in 0.09987 seconds
