Home » Modeling » TMF (Xtext) » file parsing
file parsing [message #987833] Wed, 28 November 2012 05:36 Go to next message
hi All
I'am writing again for the same problem caus i didn't understand the answer then i can' fix the problem
what i'm trying to do is to parse my file, and the code is the follow
public class RunClass implements IObjectActionDelegate {
private Shell shell;
private String fileName;
private String workingPath;
private String uriPrefix;
* Constructor for Action1.
public RunClass() {
super();
* @see IObjectActionDelegate#setActivePart(IAction, IWorkbenchPart)
public void setActivePart(IAction action, IWorkbenchPart targetPart) {
shell = targetPart.getSite().getShell();
* @see IActionDelegate#run(IAction)
public void run(IAction action) {
Term ty = null;
try {
ty = getProg().getMain();
} catch (IOException e) {
e.printStackTrace();
* @see IActionDelegate#selectionChanged(IAction, ISelection)
public void selectionChanged(IAction action, ISelection selection) {
fileName = toFileName(selection.toString());
workingPath = toWorkingPath(selection.toString());
uriPrefix = toUriPrefix(selection.toString());
private Prog getProg() throws IOException {
/*Environment configuration*/
StandaloneSetup standalone = new StandaloneSetup();
standalone.setPlatformUri(workingPath);
Injector injector = new MyDslStandaloneSetup().createInjectorAndDoEMFRegistration();
XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
/*File parsing*/
Resource resource = resourceSet.createResource(URI.createURI(uriPrefix + fileName));
InputStream in = new FileInputStream(workingPath + fileName);
resource.load(in, resourceSet.getLoadOptions());
if(resource.getContents().size() == 0) {
System.out.println("The file is empty: no folder has been generated");
return null;
Prog model = (Prog) resource.getContents().get(0);
return model;
/* SERVICE METHODS */
private String toFileName(String name) {
int idx = getLastSeparatorIndex(name);
if (idx == -1)
return "";
return name.substring(idx + 1, name.length() - 1);
private String toWorkingPath(String name) {
IWorkspaceRoot root = ResourcesPlugin.getWorkspace().getRoot();
String path = root.getLocation().toString() + "/";
if (idx == -1)
return "";
return path + name.substring(3, idx) + "/";
private String toUriPrefix(String name) {
int idx = name.indexOf('/');
if (idx == -1)
return "";
return "platform:/resource"
+ name.substring(idx, name.lastIndexOf('/')) + "/";
private int getLastSeparatorIndex(String name) {
int idx = name.length() - 1;
while (name.charAt(idx) != '/') {
idx--;
if (idx < 0)
return -1;
return idx;
so what i don't understand is why with xtext 2.0 this code work and with the latest versione didn't and rise this exception
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Content is not allowed in prolog.
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:195)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
at org.xtext.example.mydsl.ui.popup.actions.RunClass.getProg(RunClass.java:206)
at org.xtext.example.mydsl.ui.popup.actions.RunClass.run(RunClass.java:88)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3554)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3179)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.xml.sax.SAXParseExceptionpublicId: platform:/resource/prova/a.myDsl; systemId: platform:/resource/prova/a.myDsl; lineNumber: 4; columnNumber: 1; Content is not allowed in prolog.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:198)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:391)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1404)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:1014)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:625)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:488)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:819)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:748)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:123)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1208)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:525)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:392)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
... 34 more
[Updated on: Wed, 28 November 2012 05:37] by Moderator
Re: file parsing [message #987845 is a reply to message #987833] Wed, 28 November 2012 06:24 Go to previous messageGo to next message
Never never ever call mydslstandalonesetup from eclipse code
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: file parsing [message #988300 is a reply to message #987845] Thu, 29 November 2012 05:23 Go to previous messageGo to next message
ok, thanx
can you give me any reference where i can see how i can obtain the root AST element, without using mydslstandalonesetup
Re: file parsing [message #988378 is a reply to message #988300] Thu, 29 November 2012 11:30 Go to previous messageGo to next message
On 2012-29-11 11:23, mark j wrote:
> ok, thanx can you give me any reference where i can see how i can
That depends on what you want to do - which file is it you want to get
the AST for? Is it open in an editor? Do you want the dirty state or the
state saved in the file?
In general, just use EMF and open the resource; the parser is registered
for your language extension, so you will get a parsed EMF resource back
- its content is the AST model.
- henrik
Re: file parsing [message #988494 is a reply to message #988378] Fri, 30 November 2012 04:07 Go to previous messageGo to next message
yes
i want to load the Ast of the state saved in the file
if you can show me an example or some documentation, thay will help me so.
thanks
Mark
Re: file parsing [message #988572 is a reply to message #988494] Fri, 30 November 2012 09:46 Go to previous messageGo to next message
> yes
> thanks
> Mark
You use EMF to open the resource from a URI that references the resource
you want to open. Consult the EMF documentation.
Look at Resource and ResourceSet.
- henrik
Re: file parsing [message #989014 is a reply to message #988572] Tue, 04 December 2012 05:29 Go to previous messageGo to next message
hi, i readed the EMF documentation and how to open the resource so i changed my code
private IStructuredSelection selection;
IFile file = (IFile)selection.getFirstElement();
XtextResourceSet xtextResourceSet = new XtextResourceSet();
URI uri = URI.createURI(file.getFullPath().toString());
Resource resource = xtextResourceSet.getResource(uri, true);
this.selection = (IStructuredSelection)selection;
but it not work, it raise this exception, any suggestion?? how i can fix this error
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.xml.sax.SAXParseExceptionpublicId: /prova/a.myDsl; systemId: file:///prova/a.myDsl; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:159)
at org.xtext.example.mydsl.ui.popup.actions.RunClass.run(RunClass.java:96)
Caused by: org.xml.sax.SAXParseExceptionpublicId: /prova/a.myDsl; systemId: file:///prova/a.myDsl; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog.
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1284)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 32 more
Re: file parsing [message #989039 is a reply to message #989014] Tue, 04 December 2012 06:38 Go to previous messageGo to next message
Hi are you sure The file extension is correct (case sensitive) in
General you might get inspired by
http://christiandietrich.wordpress.com/2011/10/15/xtext-calling-the-gen
erator-from-a-context-menu/
Re: file parsing [message #989059 is a reply to message #989039] Tue, 04 December 2012 08:33 Go to previous messageGo to next message
yes i'm sure.
Re: file parsing [message #989125 is a reply to message #989059] Tue, 04 December 2012 12:37 Go to previous messageGo to next message
Am 04.12.12 14:33, schrieb mark j:
> yes i'm sure.
Where do you register the resource factory? Can you show the xml snippet
/ the code?
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Re: file parsing [message #989218 is a reply to message #989125] Wed, 05 December 2012 04:31 Go to previous messageGo to next message
i didn't , i figured is did automatically.. no??
if not can u give some documentation or example to do it.
thanx
Re: file parsing [message #989219 is a reply to message #989218] Wed, 05 December 2012 04:42 Go to previous messageGo to next message
if you call your code from eclipse this should happen automatically.
did you have a look at my code? it processes a model file from an eclipse command.
~Christian
Re: file parsing [message #989220 is a reply to message #989219] Wed, 05 December 2012 04:43 Go to previous messageGo to next message
no, can u give the link.
thanks
Re: file parsing [message #989242 is a reply to message #989220] Wed, 05 December 2012 05:37 Go to previous messageGo to next message
now it works. i din't nothing, only create a new project and migrate my code there.
thanx for your support.
Re: file parsing [message #989272 is a reply to message #989218] Wed, 05 December 2012 07:58 Go to previous message
Am 05.12.12 10:31, schrieb mark j:
> thanx
Make sure the plugin.xml of your runtime project uses the right file
extension.
Sebastian
Previous Topic:[Xtext] Changing java package naming after project is created
Next Topic:xtext injected parser
Current Time: Thu Jul 24 21:37:06 EDT 2025
Powered by FUDForum. Page generated in 0.28750 seconds
