Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Texo - orm annotation model has invalid default values (@Column annotation has invalid default values)
Texo - orm annotation model has invalid default values [message #988771] Sun, 02 December 2012 23:56 Go to next message
I tried to add @Column to a field and i saw that the default values for nullable,insertable,updatable are set to false. Whereas these values have to be true by default as per the @Column documentation.
http://www.oracle.com/technetwork/middleware/ias/toplink-jpa-annotations-096251.html#Column
orm-annotation @Column properties in ide
index.php/fa/12576/0/
thanks,
Pradeep V.B.
Re: Texo - orm annotation model has invalid default values [message #988807 is a reply to message #988771] Mon, 03 December 2012 04:55 Go to previous messageGo to next message
Hi Pradeep,
Thanks for noting, it was an error in the orm.xsd from eclipselink. I solved this and published a new build with the fix.
gr. Martin
On 12/03/2012 05:56 AM, Pradeep Badiger wrote:
> thanks,
> Pradeep V.B.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Texo - orm annotation model has invalid default values [message #988985 is a reply to message #988807] Tue, 04 December 2012 02:28 Go to previous messageGo to next message
Martin,
There are problems with Fetch type as well. Can you please check? Or Let me know if I can change and give a try.
thanks,
Pradeep V.B.
Re: Texo - orm annotation model has invalid default values [message #988990 is a reply to message #988985] Tue, 04 December 2012 02:55 Go to previous messageGo to next message
Hi Pradeep,
Can you give me some details (what problems?), then I can probably solve it easily. The Texo orm model is generated
directly from the orm.xsd from EclipseLink. But maybe there are more issues/incompatibilities with it.
gr. Martin
On 12/04/2012 08:28 AM, Pradeep Badiger wrote:
> Martin,
> thanks,
> Pradeep V.B.
The Netherlands
Re: Texo - orm annotation model has invalid default values [message #989208 is a reply to message #988990] Wed, 05 December 2012 03:54 Go to previous message
Hi Martin, sorry for being abstract. FetchType is LAZY by default for all of the relationships in the editor, where as it is EAGER (as per JPA spec) for few of them like "Many to One", "One to One".
Pradeep V.B.
Previous Topic:[EEF] Custom table representation
Next Topic:[EMF Facet] TreeViewer with EObject from different resource sets
Current Time: Thu Jul 24 23:32:13 EDT 2025
Powered by FUDForum. Page generated in 0.08515 seconds
