Home » Modeling » TMF (Xtext) » What's wrong with this cross-reference(I'm new to Xtext and ran into a problem)
What's wrong with this cross-reference [message #988709] Sat, 01 December 2012 13:51 Go to next message
I'm writing a DSL for a state machine. In order to keep the number of events from growing to rapidly my events have parameters. The following example shows how I'd like my DSL to work:
event LocationUpdate {
	lon : float
	lat : float
state s1 {
	LocationUpdate: lon = 20 -> s2
state s2 {
	LocationUpdate -> s1
Unfortunately I get the following error: "Description Resource Path Location Type Couldn't resolve reference to ParemeterDefinition 'lon'."
The problem is the cross-reference in the "Condition" rule of my grammar (I think), but I don't know how to fix it. Here is the whole thing:
grammar de.unisiegen.StatesLanguage with org.eclipse.xtext.common.Terminals
generate statesLanguage "http://www.eclipse.org/StatesLanguage"
StatesList :
    states += State* &
    actions += Action* &
    events += Event*
State:
    ('state'|'startstate') name = ID '{'
        actions += ActionInvocation* &
        transitions += StateTransition+
StateTransition:
    EventInvocation '->' state = [State]
ActionInvocation:
    (percent = Number '%')? action = [Action] val += Value*
Action:
    'action' name = ID '{'
        params+= ParemeterDefinition*
Event:
    'event' name = ID '{'
        params += ParemeterDefinition*
ParemeterDefinition:
    name = ID ':' type = DATATYPE
EventInvocation:
    eventName = [Event] (':' condition = Condition  (logicalOperators+= LOGICALBINARYOPERATOR conditions+= Condition)* )?
Condition:
    parameter = [ParemeterDefinition]
    eqoperator = EQUALITYOPERATOR
    val = Value
Value:
    BOOL | STRING | Number
Number:
    FLOAT | INT
enum DATATYPE:
    int|float|string|bool
terminal EQUALITYOPERATOR:
enum LOGICALBINARYOPERATOR:
    and | or
terminal BOOL:
    "true"|"false"
terminal FLOAT:
    INT'.'INT
If you can spot anything else, which seems odd or wrong to you besides the problem I described, feel free to tell me. I've never written a DSL before and take any advice I can get.
Re: What's wrong with this cross-reference [message #988722 is a reply to message #988709] Sat, 01 December 2012 22:41 Go to previous messageGo to next message
Guessing here...
Think it is because ID simple names are used everywhere, but I think the
"lon" item will get a qualified name of "LocationUpdate.lon" in the index.
Not exactly sure what you need to do; if you want to use the short name
"lon" you need to do something with scoping to make it visible at the
point where you are trying to reference it. Or you need to use FQN and
enter the reference as LocationUpdate.lon intead of just lon.
Hope that helps as a starting point for further reading.
- henrik
On 2012-02-12 2:25, Julian Dax wrote:
> lon : float
> lat : float
> state s1 {
> state s2 {
> StatesList :
> states += State* &
> events += Event*
> State:
> transitions += StateTransition+ '}'
> StateTransition:
> ActionInvocation:
> Action:
> Event:
> name = ID ':' type = DATATYPE ;
> EventInvocation:
> Condition:
> parameter = [ParemeterDefinition] eqoperator = EQUALITYOPERATOR
> val = Value ;
> Value:
> BOOL | STRING | Number ;
> Number:
> FLOAT | INT
> enum DATATYPE:
> and | or
> terminal BOOL:
> "true"|"false"
> terminal FLOAT:
> INT'.'INT
> Thanks
Re: What's wrong with this cross-reference [message #988875 is a reply to message #988709] Mon, 03 December 2012 09:14 Go to previous messageGo to next message
Thanks Henrik,
I've implemented the getScope method and now I don't get the error anymore. However autocompletion does not work. Is there anything wrong with this method or do I need to implement anything else?
public class StatesLanguageScopeProvider extends AbstractDeclarativeScopeProvider {
	public IScope getScope(EObject context, EReference reference) {
		if(context.eContainer() instanceof EventInvocationImpl){
			EventInvocationImpl eventInvocation = (EventInvocationImpl) context.eContainer();
			return Scopes.scopeFor(eventInvocation.getEventName().getParams());
		IScope scope = super.getScope(context, reference);
		return scope;
[Updated on: Mon, 03 December 2012 09:36] by Moderator
Re: What's wrong with this cross-reference [message #988900 is a reply to message #988875] Mon, 03 December 2012 11:00 Go to previous message
Never mind I think i found out how to to it. (using ProposalProvider)
Previous Topic:Migration from Xtext 1.0 to Xtext 2.31
Next Topic:Proposal - Adding internalization support to Xtext
Current Time: Wed Jul 23 23:06:59 EDT 2025
Powered by FUDForum. Page generated in 0.05366 seconds
