Home » Eclipse Projects » Eclipse 4 » CSS Styling for disabled widgets
CSS Styling for disabled widgets [message #988577] Fri, 30 November 2012 10:08 Go to next message
I read at several places that I can define a CSS styling for disabled widgets using pseudo classes such as
Text:disabled {
    background-color: #FFFFFF;
But this has no effects. (CSS styles for normal widgets works as expected).
Does anybody know the exact syntax for setting properties for disabled widgets?
Ulli
Re: CSS Styling for disabled widgets [message #988847 is a reply to message #988577] Mon, 03 December 2012 07:59 Go to previous messageGo to next message
CTabItem{
color: #00ff00;
CTabItem:selected{
color: #00ffff;
This worked for me....
Re: CSS Styling for disabled widgets [message #988853 is a reply to message #988577] Mon, 03 December 2012 08:14 Go to previous messageGo to next message
Could it be that a disabled text-field does not allow you change its
background. You can prove that by testing this in plain SWT, does the
background color change when you call setBackground on a disabled
Text-Control?
Tom
Am 30.11.12 16:08, schrieb Ulrich Obst:
> Text:disabled {
> widgets?
> Thanks
> Ulli
Re: CSS Styling for disabled widgets [message #989009 is a reply to message #988853] Tue, 04 December 2012 05:05 Go to previous message
Yes you're right. Setting the background of a disabled Text Widget has no effect either. Ok, that's a SWT issue not a CSS Bug.
Thank you for your help
Ulli
Previous Topic:Contacts Demo not working properly
Next Topic:Disable MMenu in the Main Menu
Current Time: Sun Jul 27 11:58:02 EDT 2025
Powered by FUDForum. Page generated in 0.03867 seconds
