Home » Modeling » ATL » Can I divide my script in different files?
Can I divide my script in different files? [message #988836] Mon, 03 December 2012 06:55 Go to next message
Hello!
I've just moved from mediniQVT to ATL, and I'm really happy with the performance and understandability of the code.
There is one simple thing that I miss from "programming" let's say, to modularize my files. I've checked the documentation and the forum with no luck.
I'd like to divide my ATL file in different parts, just for a matter of prolixity.
Libraries are not the solution because I only can put helpers in them, and I'd like also to include rules.
is it possible?
thank you in advance!
Re: Can I divide my script in different files? [message #988841 is a reply to message #988836] Mon, 03 December 2012 07:30 Go to previous messageGo to next message
Yes this is doable by using superimposition.
Normally this feature is for overriding rules but you can use it without overriding any rule which allow you to have one single transformation in multiple files.
Re: Can I divide my script in different files? [message #989006 is a reply to message #988841] Tue, 04 December 2012 04:47 Go to previous message
Hey! thank you!
At the begining I thought that it couldn't work because of the common lazy rules that I call from different parts of the code, I mean, from the two files considering the division... but it seems that the syntax checker don't check the referenced methods (lazy rules or called rules), is that right?
I've already done the change, and it's working
thank you!
Previous Topic:Issue in Trasformation with dot !!
Next Topic:basic ATL transformation tutorial
Current Time: Sat Jul 26 18:52:07 EDT 2025
Powered by FUDForum. Page generated in 0.07037 seconds
