Home » Modeling » Papyrus » Use Case Specification(How do I add the use case detail and project glossary)
Use Case Specification [message #988704] Sat, 01 December 2012 10:54 Go to next message
I recently downloaded Papyrus for Juno and have been playing around a bit. One of the most basic actions, once the use case diagrams have been created is to add the worded specification for each of the use cases. The usual format is a text form with headings such as: name, id, description, actors, preconditions, main flow, postconditions and alternate flow (the exact names aren't important but the information is). Can anyone tell me where you put this information?
Re: Use Case Specification [message #988792 is a reply to message #988704] Mon, 03 December 2012 03:40 Go to previous messageGo to next message
UML does not specify name, id, description, actors, preconditions, main flow, postconditions and alternate flow for use cases.
So you can adopt differents approaches:
1. You can design a profile , where you specify all this information and you apply it on use case
2. You can attach element comment to the use case
3. you can attach a word document for example to the use case by using hyperlinks (green cross)
Personnaly I prefer the profil. Thanks to the profile, information is structured and you can analyse and reuse it in model transformation.I do not if it exist a standard profil that adds this kind of information on use cases.
Re: Use Case Specification [message #988793 is a reply to message #988792] Mon, 03 December 2012 03:45 Go to previous messageGo to next message
Would it be possible for you to give me a little more information on the profile? (Maybe a sample) and tell me how to link that to the diagram?
Many thanks
Re: Use Case Specification [message #988800 is a reply to message #988793] Mon, 03 December 2012 04:40 Go to previous messageGo to next message
Hello Richard,
For modeling profiles, you should have a look at : http://www.eclipse.org/modeling/mdt/papyrus/usersTutorials/resources/PapyrusUserGuideSeries_AboutUMLProfile_v1.0.0_d20120606.pdf
(From http://www.eclipse.org/modeling/mdt/papyrus/usersTutorials/usersTutorialsIndex.php )
Camille
Re: Use Case Specification [message #988802 is a reply to message #988800] Mon, 03 December 2012 04:43 Go to previous message
Perfect, thank you
Previous Topic:how to add variables to a transition in StateMachine Diagram?
Next Topic:types of interface
Current Time: Wed Jul 23 02:47:47 EDT 2025
Powered by FUDForum. Page generated in 0.33183 seconds
