Use Case Specification [message #988704] |
Sat, 01 December 2012 10:54  |
I recently downloaded Papyrus for Juno and have been playing around a bit. One of the most basic actions, once the use case diagrams have been created is to add the worded specification for each of the use cases. The usual format is a text form with headings such as: name, id, description, actors, preconditions, main flow, postconditions and alternate flow (the exact names aren't important but the information is). Can anyone tell me where you put this information?
Re: Use Case Specification [message #988792 is a reply to message #988704] |
Mon, 03 December 2012 03:40   |
UML does not specify name, id, description, actors, preconditions, main flow, postconditions and alternate flow for use cases.
So you can adopt differents approaches:
1. You can design a profile , where you specify all this information and you apply it on use case
2. You can attach element comment to the use case
3. you can attach a word document for example to the use case by using hyperlinks (green cross)
Personnaly I prefer the profil. Thanks to the profile, information is structured and you can analyse and reuse it in model transformation.I do not if it exist a standard profil that adds this kind of information on use cases.
FUDForum. Page generated in 0.32081 seconds
