Home » Modeling » EMF » Filter notifications when resource is loading
Filter notifications when resource is loading [message #988705] Sat, 01 December 2012 12:47 Go to next message
I'm trying to create an adapter for certain models of EMF Eclipse that must capture the "add" notifications. What it should do is that when I add something to the model must show a dialog asking some questions.
However when I open the model, I'm receving lots of add notifications. I suppose that it's normal, because when you open a model it must load all its features and emf must add them to the in memory model (or something similar, I'm a newbie in emf).
But that's a serious problem because I don't know what "add notifications" are coming from the model loading or from an interaction of the user.
Is it possible to make a filter to skip all the notifications coming from the load of the model?
Thanks a lot!
Re: Filter notifications when resource is loading [message #988724 is a reply to message #988705] Sun, 02 December 2012 01:21 Go to previous messageGo to next message
Aarón,
How are the adapters attached? You should consider attaching them in
response to the Resource.RESOURCE__IS_LOADED notification much like
org.eclipse.emf.ecore.change.util.ChangeRecorder.notifyChanged(Notification)
does. You can also guard with
((Resource.Internal)eObject.eResource()).isLoading().
> Thanks a lot!
Re: Filter notifications when resource is loading [message #988725 is a reply to message #988705] Sun, 02 December 2012 01:21 Go to previous messageGo to next message
Aarón,
> Thanks a lot!
Re: Filter notifications when resource is loading [message #988726 is a reply to message #988705] Sun, 02 December 2012 01:21 Go to previous messageGo to next message
Aarón,
> Thanks a lot!
Re: Filter notifications when resource is loading [message #988727 is a reply to message #988705] Sun, 02 December 2012 01:21 Go to previous messageGo to next message
Aarón,
> Thanks a lot!
Re: Filter notifications when resource is loading [message #988728 is a reply to message #988705] Sun, 02 December 2012 01:21 Go to previous messageGo to next message
Aarón,
> Thanks a lot!
Re: Filter notifications when resource is loading [message #988729 is a reply to message #988705] Sun, 02 December 2012 01:21 Go to previous messageGo to next message
Aarón,
> Thanks a lot!
Re: Filter notifications when resource is loading [message #988730 is a reply to message #988705] Sun, 02 December 2012 01:21 Go to previous messageGo to next message
Aarón,
> Thanks a lot!
Re: Filter notifications when resource is loading [message #988731 is a reply to message #988705] Sun, 02 December 2012 01:21 Go to previous messageGo to next message
Aarón,
> Thanks a lot!
Re: Filter notifications when resource is loading [message #988732 is a reply to message #988705] Sun, 02 December 2012 01:21 Go to previous messageGo to next message
Aarón,
> Thanks a lot!
Re: Filter notifications when resource is loading [message #988733 is a reply to message #988705] Sun, 02 December 2012 01:21 Go to previous messageGo to next message
Aarón,
> Thanks a lot!
Re: Filter notifications when resource is loading [message #988743 is a reply to message #988733] Sun, 02 December 2012 07:27 Go to previous message
Wow ten replies! Laughing
But with this piece of code:
!((Resource.Internal)notification.getNotifier().eResource()).isLoading()
It worked like a charm, thanks a lot!
Previous Topic:[EMF] Implementing Instance Model Inheritance
Next Topic:[CDO] get deleted Revision/CDOObject
Current Time: Wed Jul 23 11:53:12 EDT 2025
Powered by FUDForum. Page generated in 0.06999 seconds
