Home » Modeling » EMF » [CDO] Install CDO Server in linux
[CDO] Install CDO Server in linux [message #988521] Fri, 30 November 2012 05:58 Go to next message
Hi, I need to run CDO-Server in a linux environment. In your opinion, which one is the better configuration?
- without osgi container (a classic Java application)?
- with osgi container?
- using spring framework?
Moreover in your opinion: is it appropriate to build the application using a daemon-service architecture? If yes, is it enough a bash script that controls the application lifecycle or are there other techniques more suitable?
Thanks everyone.
Re: [CDO] Install CDO Server in linux [message #988560 is a reply to message #988521] Fri, 30 November 2012 09:07 Go to previous message
Am 30.11.2012 11:58, schrieb Giovanni Colasurdo:
That only depends on your requirements and preference.
I've no experience with CDO plus Spring framework. I suspect it would require quite some extra work.
Yes, why not.
That depends on whether you use OSGi or not. In OSGi you could configure a remote port to get access to the console. In
standalone you'd need to come up with your own mechanism to shutdown properly.
Cheers
/Eike
http://www.esc-net.de
Previous Topic:[EMF] Notification.REMOVE_MANY not used.
Next Topic:Best practice for building eclipse data explorer view .
Current Time: Fri Jul 25 16:06:46 EDT 2025
Powered by FUDForum. Page generated in 0.05276 seconds
