Home » Language IDEs » Java Development Tools (JDT) » Unit tests for Eclipse SDK itself
Unit tests for Eclipse SDK itself [message #988274] Thu, 29 November 2012 04:16 Go to next message
Do Eclipse SDK developers use unit testing for the Eclipse itself?
If so, where can i get those tests?
I am interested in the unit tests for Eclipse SDK Version: 3.8.1 or higher.
Thank you!
Re: Unit tests for Eclipse SDK itself [message #988427 is a reply to message #988274] Thu, 29 November 2012 16:08 Go to previous message
We certainly do.
As you're asking in the JDT forum, you'll find the JDT tests below http://git.eclipse.org/c/jdt
Look at all the projects with "tests" in their names.
If you clone the corresponding git repos and import all projects into your workspace running these tests should be fairly straight forward. Running these tests outside the IDE is much more involved.
HTH,
Stephan
Previous Topic:Eclipse freezes when using xml schema editor
Next Topic:Running Java with Eclipse
Current Time: Fri Jun 06 02:04:55 EDT 2025
Powered by FUDForum. Page generated in 0.28726 seconds
