Home » Eclipse Projects » Remote Application Platform (RAP) » Throws unexpected "Graphic is diposed" exception
Throws unexpected "Graphic is diposed" exception [message #988253] Thu, 29 November 2012 01:37 Go to next message
Project use WAR Product Configuration deploy to tomcat6, not fixed Throws unexpected "Graphic is diposed" exception
Re: Throws unexpected "Graphic is diposed" exception [message #988255 is a reply to message #988253] Thu, 29 November 2012 01:49 Go to previous messageGo to next message
in order to help at least RAP version and the stack trace of the
exception is needed.
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Throws unexpected "Graphic is diposed" exception [message #988272 is a reply to message #988255] Thu, 29 November 2012 04:14 Go to previous messageGo to next message
RAP version: RAP2.0M1
exception reference attachment.
thanks a lot.
  • Attachment: stack.png
    (Size: 999.51KB, Downloaded 282 times)
[Updated on: Thu, 29 November 2012 04:17] by Moderator
Re: Throws unexpected "Graphic is diposed" exception [message #988443 is a reply to message #988272] Thu, 29 November 2012 17:00 Go to previous messageGo to next message
This can happen if the same image is used in two sessions and gets disposed in one of the sessions. Check you're creating new images for each session when setting the column header image.
Re: Throws unexpected "Graphic is diposed" exception [message #988460 is a reply to message #988443] Thu, 29 November 2012 19:29 Go to previous messageGo to next message
action and control icons is used the image tools class set
Snippet:
public class ImageUtil {
private static ImageRegistry registry = new ImageRegistry();
* get image
* @param fileName file path
* @return
public static Image getImage(String fileName) {
Image image = registry.get(fileName);
if (image == null) {
image = Activator.getImageDescriptor(fileName).createImage();
registry.put(fileName, Activator.getImageDescriptor(fileName));
return image;
Re: Throws unexpected "Graphic is diposed" exception [message #988492 is a reply to message #988460] Fri, 30 November 2012 03:52 Go to previous messageGo to next message
That's the problem. Your ImageRegistry is stored in a static variable, so it, and all the images inside it are shared between sessions.
Re: Throws unexpected "Graphic is diposed" exception [message #988517 is a reply to message #988492] Fri, 30 November 2012 05:41 Go to previous messageGo to next message
Modified create the image, but also Throws unexpected "Graphic is diposed" exception.
What other methods?
Snippet:
* get image
* @param fileName
* @return
return Activator.getImageDescriptor(fileName).createImage();
* get ImageDescriptor
* @param fileName
* @return
public static ImageDescriptor getImageDescriptor(String fileName) {
return Activator.getImageDescriptor(fileName);
[Updated on: Thu, 06 December 2012 00:34] by Moderator
Re: Throws unexpected "Graphic is diposed" exception [message #989402 is a reply to message #988517] Thu, 06 December 2012 00:38 Go to previous message
Different client access.
This is what is the reason? What solutions?
thanks
Previous Topic:Themes in RAP 2.0 M3
Next Topic:Hide Empty Submenus
Current Time: Fri Sep 26 13:14:05 EDT 2025
Powered by FUDForum. Page generated in 0.05081 seconds
