Home » Newcomers » Newcomers » Not getting nullpointer's stack trace on console (java code)
Not getting nullpointer's stack trace on console (java code) [message #987595] Tue, 27 November 2012 04:53 Go to next message
I have an annoying problem: Eclipse doesn't print stacktrack to the console if there is a nullpointer exception. However, I do get stacktrace if some other exception happens... And used to have nullpointer exceptions on the console before. I have no idea why I don't get them anymore.
When a nullpointer occurs Eclipse stops executing the thread (in debug-tab's thread listing) at EventDispatchTread.run() -methods third last line (line 156). On that line there is only }.
Unfortunately I can't provide a screenshot...
I'm using Indigo Service Release 2 and coding with java 6.
Re: Not getting nullpointer's stack trace on console (java code) [message #988247 is a reply to message #987595] Thu, 29 November 2012 01:01 Go to previous messageGo to next message
Over 500 views and no one has experienced the same?
Re: Not getting nullpointer's stack trace on console (java code) [message #988251 is a reply to message #987595] Thu, 29 November 2012 01:17 Go to previous messageGo to next message
Antti,
You've not even shown any code. It might well be the case that a null
pointer is caught and ignored, but without context
On 27/11/2012 2:03 PM, Antti Rumpunen wrote:
So your question is about java.awt.EventDispatchThread.run()? You can
set a NullPointerException breakpoint (in the Breakpoints view) and see
how that exception is propagated and whether anything on the call stack
will catch it and dump it.
Re: Not getting nullpointer's stack trace on console (java code) [message #988254 is a reply to message #988251] Thu, 29 November 2012 01:39 Go to previous messageGo to next message
yes your code seems to engulf the exception. show us the code (may be partial if it is too sensitive)
Re: Not getting nullpointer's stack trace on console (java code) [message #988297 is a reply to message #988254] Thu, 29 November 2012 05:13 Go to previous messageGo to next message
I tested with a simple code (Integer i = null; if(i>0)) which will cause a nullpointer every time I press a button. The code is executed twice by the same thread every time I press the button. Sometimes I get two nullpointer stack traces on the console (without Eclipse stopping the AWT-EventQueue-0 thread) and sometimes I get only one stack trace on the console and Eclipse stopping the AWT-EventQueue-0 thread.
Here is what Eclipse shows me...
Thread...
Thread...
Thread [AWT-EventQueue-0] (Suspended (exception NullPointerException))
EventDispatchThread.run() line:156 [local variables unavailable]
Thread...
Thread...
I can't provide the real code because there is thousands of lines of code and I have no idea where the nullpointer comes from. I debugged what the thread (AWT-EventQueue-0) is doing after I press the button (not my test button). The whole execution goes well. But once the thread starts to do something else (no idea what) I get the nullpointer (with Eclipse stopping the thread every time)...
[Updated on: Thu, 29 November 2012 05:14] by Moderator
Re: Not getting nullpointer's stack trace on console (java code) [message #988298 is a reply to message #988297] Thu, 29 November 2012 05:18 Go to previous messageGo to next message
Have you set a NullPointerException breakpoint to figure out where it's
happening?
> thread.
> Thread...
> Thread...
> Thread...
> Thread...
> what the thread (AWT-EventQueue-0) is doing after I press the button.
Re: Not getting nullpointer's stack trace on console (java code) [message #988313 is a reply to message #988298] Thu, 29 November 2012 06:22 Go to previous messageGo to next message
Thanks Ed for replying,
I assume have access to EventDispatchThread so you can see the lines... I added a breakpoint to EventDispatchThread.run() -method's line 153. It steps from 153 to 155 and then it steps to 156 (which is the end of synchronized-block). After that when I take the next step I get NullPointerException. Does it mean that theQueue -object is null or what? At least it doesn't seem to be null in Eclipse's Variables-tab.
Re: Not getting nullpointer's stack trace on console (java code) [message #988317 is a reply to message #988313] Thu, 29 November 2012 06:45 Go to previous messageGo to next message
Antti,
It sounds like you've not set a NullPointerException breakpoint which
you can do in the Breakpoint view via that little icon that looks like
J! so please try that to answer the question yourself.
On 29/11/2012 12:22 PM, Antti Rumpunen wrote:
> Thanks Ed for replying, I assume have access to EventDispatchThread so
Re: Not getting nullpointer's stack trace on console (java code) [message #988325 is a reply to message #988317] Thu, 29 November 2012 07:06 Go to previous messageGo to next message
Hehheh, didn't know that you could set that kind of breakpoints... Problem solved. Thanks Ed!
There was the following piece of code in which window was null. No idea why the focus is set like that (not my code). And the reason why Eclipse doesn't show stacktrace to that line is probably something that needs more indepth understanding about threads etc.
EventQueue.invokeLater(new Runnable()
  public void run()
    window.setFocus();
Re: Not getting nullpointer's stack trace on console (java code) [message #1621418 is a reply to message #988325] Tue, 17 February 2015 17:05 Go to previous message
Hello Guys,
I found this error coming at runtime in my Swing code. I hadn't handled an exception and hence this was not working and was showing the Dispatch Thread message.
I accept the error display is not explanatory in this case.
Vishal Kumar
Previous Topic:Jetty SSL Exception : Connection was aborted
Next Topic:How to extract class hierarchy/call graph relationships from java sources?
Current Time: Sat Jul 26 20:40:53 EDT 2025
Powered by FUDForum. Page generated in 0.09262 seconds
